expecting T_STRING T_VARIABLE T_NUM_STRING
Thread begun 4/16/2014 9:46 am by Paul | Last modified 4/16/2014 1:00 pm by Jason Byrnes | 3741 views | 10 replies |
Paul
This is the complete error I am receiving once I submit a form.
Parse error: syntax error, unexpected '"', expecting T_STRING or T_VARIABLE or T_NUM_STRING in /webroot/c/e/centu002/primary/www/webassist/email/waue_sellform_1.php on line 27
Here is line 27:
$WA_MailObject = WAUE_AddAttachment($WA_MailObject,"".$WA_DFP_UploadStatus["WA_UploadResult2"]["serverDirectory"] ."?php echo $WA_DFP_UploadStatus[".$WA_DFP_UploadStatus["WA_UploadResult2"]["serverFileName"] ."?php echo $WA_DFP_UploadStatus[");
Anyone have any thoughts?
See PM
change that line to:
$WA_MailObject = WAUE_AddAttachment($WA_MailObject,"".$WA_DFP_UploadStatus["WA_UploadResult2"]["serverDirectory"] ."".$WA_DFP_UploadStatus["WA_UploadResult2"]["serverFileName"]."");
Paul
Jason,
Thanks. It worked perfectly except I'm only getting one image in the email. I tested it with uploading images using both File Fields.
Any thoughts?
you only have one attachment set up, you need to edit the UE behavior to set up the second attachment
Paul
See PM
Paul
PM
Paul
That did it, Jason!
Thanks for your help!
in the webassist/email/waue_sellform_1.php file I changed:
[code]$WA_MailObject = WAUE_AddAttachment($WA_MailObject,"".$WA_DFP_UploadStatus["WA_UploadResult2"]["serverDirectory"] ."".$WA_DFP_UploadStatus["WA_UploadResult2"]["serverFileName"]."");[code]
$WA_MailObject = WAUE_AddAttachment($WA_MailObject,"".$WA_DFP_UploadStatus["WA_UploadResult1"]["serverDirectory"] ."".$WA_DFP_UploadStatus["WA_UploadResult1"]["serverFileName"]."");[code]
on the sellform.php page, you had both uploads set to use the file file field, i edit that so one used the file filed and the other used the Contact_me_group_2_File field so that both images would be uploaded.
Paul
So grateful...thanks!
