screwed up CSS in firefox
Thread begun 8/21/2009 9:52 am by phil366681 | Last modified 8/25/2009 10:33 am by Jimmy Wu | 2824 views | 3 replies |
phil366681
Hi All
Does anyone know why when accessing powerstore via firefox the CSS is all screwed up with it off to the right all the time?
It works no problem in explorer!!
Cheers all
Jimmy Wu
Do you have a url to your PowerStore where I can see this issue?
phil366681
I only have it on my own testing server. I have however attached a screen shot of what happens.
Not sure if you can shed some light on this from that?
I've not actually done anything with the store. Just loaded it and testing the pages to make sure there are no bugs before i start and so far the only one found was that the CSS on the main editable region.
Jimmy Wu
Ah, yes, this is the issue where one of the functions we used is not longer supported in the latest version of PHP. In your CSSMenuWriter/cssmw_home/menu.php and CSSMenuWriter/cssmw_admin/menu.php replace the function split to be explode.
You can just do a search and replace on split with explode. There should be one call to the function in each file.
This should be fixed in the next release of the product.
