Power CMS Power Gallery inclusion error
Thread begun 4/14/2014 3:21 pm by kata387222 | Last modified 1/29/2015 9:36 am by Jason Byrnes | 5553 views | 13 replies |
kata387222
Hi
I have installed Power CMS on my site and on pages that have a Power Gallery inclusion I am getting the following error:
Warning: opendir(/home/mindwork/public_html/otel/WA_Globals/galleries/ribbon_fullsize_lightbox/css/themes) [function.opendir]: failed to open dir: No such file or directory in /home/mindwork/public_html/otel/powergallery/admin_gallery/common/functions.php on line 490
I have been through the threads and seems that the functions.php file may need tweaking - Not sure what to though.
i am on DW CS6 and using Design Extender 1.1.7 and Databridge 1.1.9
See below for code with and without Power CMS added.
your help will be greatly appreciated.
Thanks Kata
Here is the code with Power CMS added to page with existing Power Gallery (this code is returning the error):
<body>
<h4>Curtain Side Bodies</h4>
<div class="galContainer">
<div class="galCopy"> <?php echo WA_getCMSContent($database_PowerCMSConnection, $PowerCMSConnection, 'Vehicle Builds', 'Curtain Sides'); ?> </div>
<div class="galPlug">
$pg_id = '4';
$pg_theme = 'otel';
include('/home/mindwork/public_html/otel/powergallery/galleries/ribbon_fullsize_lightbox/index.php');
<!--end galPlug--></div>
<br class="clearfloat" />
<!--end galContainer--></div>
<div class="clearfloat"> </div>
<?php WA_manageSEO(); ?>
</body>
Here is the Original Code prior to adding Power CMS where the gallery was working fine:
<body>
<ul>
<li>Any length and width
</li>
<li>Timber decks; either Shiplap hardwood Balau, Calophylum or Heavy Hopea, Trans Tek, container ply 25 0r 28mm or just treated plywood
</li>
<li>Steel decks; either mild steel plate, corten plate or treadplate at what ever thickness required
</li>
<li>Load anchorage rails with hooks and or chain plates if required
</li>
<li>Lashing rings fitted into deck if required
</li>
<li>Flush mounted headboards lined with ply or steel on inside
</li>
<li>Roof support poles as required to suit body length (our own unique design)
</li>
<li>One piece aluminum roof
</li>
<li>T3 curtain tensioners
</li>
<li>Curtains to colour of your choice rated as per LTNZ requirements
</li>
<li>Pressed steel mudguards and OTEL embossed mudflaps
</li>
<li>Tail lifts, what ever brand/style you require
</li>
<li>Optional folding or removable internal side screens and rails
</li>
<li>All painted to your requirements</li>
</ul>
</div>
$pg_id = '4';
$pg_theme = 'otel';
</body>
</html>
kata387222
Here's the details. Thanks
i updated the powergallery/admin_gallery/common/functions.php file to fix the problem.
kata387222
Thanks so much. Is it possible to tell me what the problem was and the change that was needed so I can fix myself in the future? Is this problem avoidable by doing something different?
i added this code at line 2:
$GLOBALS['galabsLink'] = str_replace("/WA_Globals", "/powergallery", $GLOBALS['absLink']);
the code may be different if the power gallery files are installed to a different folder.
i then changed both instances of:
$GLOBALS['absLink']
in that file to:
it is a conflict caused by both power gallery and Power CMS using the same variable to set the root, but power gallery needs to point to a different folder.
kata387222
Thanks a lot, that clears it up.
you're welcome.
mick358555Beta Tester
Same Error Message, different result after modification.
Hi Jason, I get the same error message as this user but when I apply the same fix you offered I still get issues. Simply put if I put my Gallery code first and my CMS code next it displays correctly, if I place it CMS Code first followed by the powergallery code I get the ' [function.opendir]: failed to open dir: No such file or directory' error. This is the code I am using:
<!--This is the gallery -->
$pg_id = '1';
$pg_theme = 'Gaiety 01';
include('/home/fhlinux190/g/gaietyballoons.co.uk/user/htdocs/powergallery/galleries/grid_lightbox/index.php');
<!--This is the CMS area for the descriptor -->
include('/home/fhlinux190/g/gaietyballoons.co.uk/user/htdocs/WA_CMS/addtosite.php');
echo WA_getCMSContent($database_PowerCMSConnection, $PowerCMSConnection, 'Gallery Descriptors', 'Airwalkers', false);
This works albeit the CMS dialog is displayed after the gallery, I want the CMS dialog to precede the gallery, but reversing the code thus:
$pg_id = '1';
This gives the error.
