Validation not working, emails not sending, no errors.
Thread begun 4/13/2014 9:32 pm by Lee Firth | Last modified 4/28/2014 6:19 am by Jason Byrnes | 7023 views | 22 replies |
Lee Firth
I have applied a simple contact form to my page and set it up to email the contents but nothing gets sent and the validation doesn't work. At least nothing is displayed, I think the form is actually being validated because invalid=true is appended to the url.
The page is zebraprintersonline.com.au/contact-us.php
You will need a username and password to view the page as it's under development. The username is zebra and the password is al765bd
Lee Firth
See private message.
in the universal email behavior, you have left the go to setting empty.
edit the universal email instance on the page and set the go to page to redirect to a success page.
Lee Firth
Hi Jason, thanks for pointing that out, but that wasn't the issue I am concerned about, that shouldn't stop an email from being sent. My issues are:
The WebAssist form validation doesn't work and the form does not send.
I added code to write the session to the page, then tested.
it is submiting the form fine form me, and writing the email log to the page as:
["waue_contact-us_1_Log"]=>
string(61) "Sending To: sales@zebraprintersonline.com.au... Success
so it is saying that the email is being transferred to the SMTP server.
if you are not receiving the email, then the SMTP Server is not relaying it to you for some reason.
double check that the from address is a valid email address for your domain and that the SMTP server are correct for your host.
Lee Firth
My apologies, I was sending to a non existing email address.
That only leaves the validation not working.
I am not able to reproduce, the validation is working fine for me.
Lee Firth
What browser are you using? Validation sort of works in Firefox although I think that it's the browser validation not WebAssist and it will submit regardless of what you put in the security field. Safari will submit a blank page.
I've used Fire Fox, Safari and IE on both Mac and Windows and cannot reproduce the problem, the validation is working fine in my tests.
