Error Generating Form
Thread begun 4/12/2014 1:33 pm by ed331947 | Last modified 4/14/2014 8:50 am by ed331947 | 1054 views | 2 replies |
ed331947
I'm using the checkout wizard and am getting the following error: Error generating form: TypeError: wa.spry_shared has no properties. It is showing as I go from tab to tab. When the wizard finished, the following error message occurred:
This document contains JavaScript cod for a widget that no longer exists. If you don't remove the code, the browser might display JavaScript errors when loading the page.
Widget: var Company_Name_Spry = new Spry.Widget.ValidationTextField("Company_name_Spry","none",{validateOn:["blur"]});
There were several very similar to this.
What version of eCart are you using?
The new eCart 6 does not use spry validation. so it sounds like you are using an older version of eCart.
Is the first time running the checkout wizard? The error description sounds like you may have run the checkout wizard once to create the pages and are running the wizard again. If you need to run the wizard a second time, you should delete the existing checkout pages first.
ed331947
I was running 5.0 then upgraded both on my desktop and laptop. It worked on my laptop so I copied all the files from there to my desktop. I'll try running a fresh shopping cart from that.
