Universal Email NOT working
Thread begun 4/10/2014 12:44 pm by MaikelZwart | Last modified 4/10/2014 1:49 pm by Jason Byrnes | 2254 views | 4 replies |
MaikelZwart
I want to create an email message, but when I save my message, the settings from universal email are empty again and my message is not saved.
I deleted my configuration folder and downloaded and reinstalled Data Bridge 1.1.9 and eCart 6.0.6 but with no luck
I deleted eCart but I still can't make an email message...
How can I get this to work?
tnx in advance!
MaikelZwart
Got it to work
I figured it out...
Universal email does not work on a page witch does not have the <html><body></body></html> tags...
Because I include my page I don't want those tags!
For now I include those tags before running Universal Email
"Because I include my page I don't want those tags!"
so you add UE to page that you use the php include function to add it to another page:
<?php include("UEpage.php"); ?>
is that correct?
if so, that is a bad idea, the problem with this is that it will add the php code for sending the email within the body of the page it is being included to.
Instead, you should use framework builder to add the UE page to another page as a plugin. The advantage of plugins is that it takes the pieces of the page: code above the doctype, code within the head and code within the body and adds it in the correct places in the page it is being p[lugged into. this will make it so the UE behavior code gets placed in the right location above the doctype, so that if it needs to redirect to another page after submitting, it wont cause errors.
MaikelZwart
Thank you for your reply!
I have not used the framework builder, but I will take a look at it!
greetings, Maikel
you're welcome.
