file manager problem when adding images from sub directory
Thread begun 4/10/2014 1:08 am by CraigR | Last modified 4/10/2014 12:48 pm by CraigR | 1467 views | 2 replies |
CraigRBeta Tester
I have an admin form to add product details to the database table.
My form uses the file manager to add an image url to the relevant field.
If I browse to the images folder, the path is stored correctly
eg /images/logo.png
if I browse to a sub folder of images, the path is stored correctly
eg /images/details/ logo.jpg
However, if I browse another level deeper, the path is stored incorrectly
eg /images/details\more/ logo.jpg
(Notice the folder separator is inverted from a forward slash to a backslash, after the first sub-folder)
If I try adding a further level, the problem is exacerbated
eg /images/details\more\evenmore/ logo.jpg
**UPDATE**
I uploaded the site to my testing server, in case you needed to see the issue first hand, but it works ok there
I cant really say why the paths would be like that on your local server but work on the remote server, must a configuration setting on your local server causing the path problem.
I tried generating the file manager from the Form Insert and as a stand alone, and cannot reproduce the problems.
At least it is working on the live server though.
CraigRBeta Tester
Yeah, strange one that.
I can likely do a fix locally with a str_replace()
