Add time picker to date picker
Thread begun 4/10/2014 12:51 am by gstoyle396649 | Last modified 6/02/2021 4:44 pm by Ray Borduin | 2375 views | 4 replies |
gstoyle396649
Is it possible to add this jquery plugin to the datepicker in order to enable the timepicker?
http://trentrichardson.com/examples/timepicker/
This would be very useful.
Thanks.
It looks like it should be fairly strait forward to add the time picker based on the documentation on the site.
add the link to the time picker JS file on that site.
add the CSS that they give forthe time picker, then edit the datepicker that is added to change:
$('#datepicker_1').datepicker({
you may have a different ID, to use the datetimepicker instead:
$('#datepicker_1').datetimepicker({
should be fairly easy to implement, but we cannot offer support for it.
DeanCollins
I spent hours trying to get this to work. Probably just me.
But this one took only minutes: http://mugifly.github.io/jquery-simple-datetimepicker/
Nathon Jones Web Design
Originally Said By: DeanCollins
Huge help...thank you. Datetimepicker was beginning to unpick my sanity.
Don't suppose you worked out how to change the pointer to an arrow when selecting a date? It shows as an Insert, by default.
The default cursor can be adjusted in css.
cursor: pointer;
