Grey area around map and marker not in centre of map
Thread began 8/21/2009 8:49 am by colin282897 | Last modified 8/21/2009 3:25 pm by Jason Byrnes | 1988 views | 3 replies |
colin282897
I have a small map that when i click the map shows a larger map. The maps both do not have the marker in the centre of the map and the large version has a large amount of grey around it.
How can I centre the marker and get rid of the grey?
Please post a link where can see the problem to investigate the cause.
colin282897
directory_listing.php
just try the top sun as the other has another problem to another post re repeat regions and maps
regiontest.php
this one is simpler and stripped down. should show lots of names with a map for each.
I have created a technical support ticket to look into this with you.
To view and edit you support ticket, log into your support history:
