Log in fail breaking page
Thread begun 4/08/2014 8:26 am by iainmacdonald331081 | Last modified 4/08/2014 12:33 pm by Jason Byrnes | 4525 views | 7 replies |
iainmacdonald331081
Have just spotted a glitch on a log in page - if the incorrect details are entered the page gets messed up when it reloads after an invalid username and password.
I suspect its because of a URL rewrite on the page, but I can't get the fail redirect right.
The page without the rewrite is here:
http://www.safariawards.com/africa/index.php?GSG_URL=zarafacamp
(Which is screwed up too, but not so much an issue)
With the rewrite, the URL would be:
http://www.safariawards.com/africa/zarafacamp/
Which is fine. But if you try any random username and password to log in, it gets messed up.
The success redirect URL is: "successRedirect" => "../africa/".$_SESSION["GSG_URL"]."/",
And the fail redirect is currently the default one: "failRedirect" => "index.php?failedLogin=1",
Based on that what should the fail redirect be to reload the page correctly?
Thanks.
(I've attached a copy of the page just in case.)
you want the failed URL to reload the same page with the re written URL right?
so use that as the failed redirect:
"failRedirect" => "/africa/zarafacamp/index.php?failedLogin=1",
iainmacdonald331081
Thanks Jason - penny drops and see that its just adding index.php?failedLogin=1, so I changed it to:
"failRedirect" => "../africa/".$_SESSION["GSG_URL"]."/index.php?failedLogin=1",
Which seems to work, although the login fail message isn't appearing. (It was before on the page that wasn't displaying correctly).
iainmacdonald331081
Thanks Jason.
your rewrite rule needed to be edited to include the [QSA] flag:
RewriteRule (.*)/ index.php?GSG_URL=$1 [QSA]
  When the replacement URI contains a query string, the default behavior of RewriteRule is to discard the existing query string, and replace it with the newly generated one. Using the [QSA] flag causes the query strings to be combined.
Consider the following rule:
RewriteRule /pages/(.+) /page.php?page=$1 [QSA]
With the [QSA] flag, a request for /pages/123?one=two will be mapped to /page.php?page=123&one=two. Without the [QSA] flag, that same request will be mapped to /page.php?page=123 - that is, the existing query string will be discarded.
http://httpd.apache.org/docs/current/rewrite/flags.html#flag_qsa
iainmacdonald331081
Thanks Jason - that's probably one I would have struggled to figure out in a hurry.
you're welcome.
