Activation screen keeps coming up when trying to use Universal email in Databridge
Thread begun 4/07/2014 7:30 pm by Blikbrein | Last modified 4/11/2014 11:54 am by Jason Byrnes | 3050 views | 8 replies |
Blikbrein
Installed latest update 1.1.9 and other extensions,to my knowledge, works fine. Universal email however keeps popping up a registration screen every time I try to use it. I never get past this screen to use the extension. It pops up twice and then disappears together with the extension window. No way to get into and use Universal Email. Using DW CS6
please send a screen shot of the extension manager showing the extensions and version numbers that are installed.
Blikbrein
Attached
Hmmm, so Design Extender and data Bridge are the only WebAssist Extensions.
try uninstalling Data Bridge from the extension manager, then reinstalling it.
after it is installed in the extension manager, open Dreamweaver and a php page to trigger the WebAssist installer. Once the WebAssist installer completes, restart Dreamweaver
Blikbrein
Already tried this. Did not work. Cleared the cache - all the usuals...
try using the Data Assist wizard, then accessing Universal Email, if you still have the same issue, Please provide a Skype username or a US phone number and a good time to contact you when you will be in front of your computer and we will have an engineer contact you to resolve this issue over the phone.
We are available Monday - Friday from 9am - 4pm EST (except major U.S. holidays).
Blikbrein
Also tried this already
marcel303333
I have the same issue. Is there already a solution for the problem?
the Data Bridge and eCart installation files have been recompiled to correct this problem.
if you uninstall eCart 6.0.6 and / or Data Bridge 1.1.9 then reinstall them, it should fix the problem.
