Checkout page not redirecting initially
Thread begun 4/07/2014 10:51 am by Jedi | Last modified 4/08/2014 11:56 am by Jason Byrnes | 3820 views | 7 replies |
Jedi
My Continue button on the checkout page does not bring up the confirm page on first click. It does on either the second or third click.
I am using eCart 6.0.6 and Databridge 1.1.9
Jedi
Ok thanks Jason. See pm
the error console is showing that the following file is not uploaded to the server:
webassist/forms/WA_ShowCVV.js
please make sure to upload that file to the server, that file missing may be causing the problem.
Jedi
That file was not created on my site. How do i create it wtihout changing everything on my site?
attached is a copy of that file to place in your site, not sure why it wouldn't get created after running the wizard
Jedi
Thanks Jason,
I have noticed that when I try to uninstall eCart to upgrade to eCart 6.0.6 and then reninstall it that I get the message :
While executing timer, the following JavaScript error occurred:
At line 139 of file xxx/xx/xxx/Adobe Dreamweaver CS5.5\Configuration\Commands\WA_uninstall2.htm:
shareMatch has no properties
Once I install 6.0.6 I don't get any more javascript errors
Could this be a problem?
no, it shouldn't be a problem.
you don't really need to run the WA uninstall routine when installing the update 6.0.6.
simple open the Extension manager, uninstall the 6.0.5 version, install the 6.0.6 version, then open DW and a php page to start the installation process for 6.0.6.
it will overwrite the files from 6.0.5 when running the WebAssist installer.
