Login / Session Problems
Thread begun 4/03/2014 2:15 am by Paolo R | Last modified 4/03/2014 12:25 pm by Jason Byrnes | 3788 views | 5 replies |
Paolo R
Allow Access if ID is same as session ID value
Hi Guys,
I'm just creating an edit profile page.
Basically it's working great when I get there by the URL parameter ID is = session value.
However, I want to limit the access so that only that person can change their profile.
E.G
editprofile.php?ID=6 = Mr Bloogs
editprofile.php?ID=5 = Mr Smith
I am logged in as Mr bloogs, if I change the ID i can change a different profile.
I've set up a rule for show region if ID = Session value but it's not working.
Can you help?
Attached is the page grab.
Thanks,
Paolo
you would not use an access rule for this.
you would filter the recordset on the page to filter the ID column by the ID session variable instead of using the ID URL variable.
Paolo R
Hi Jason,
I've done as you have suggest and I can see that the correct ID is going in the URL parameter but it's not displaying anything.
are you sure you have the right session name?
add the following code to the page to write the session information:
<?php var_dump($_SESISON); ?>
it will include the session names and values, make sure you are using the right session name.
Paolo R
Interesting... It's showing as Null... Evening on the page where It says "Welcome Paolo" - Which is a session variable in the record set!
add the following code at line 1:
<?php @session_start(); ?>
