Posting from dynamic page
Thread begun 3/31/2014 7:09 am by larry268887 | Last modified 3/31/2014 1:01 pm by larry268887 | 2669 views | 7 replies |
larry268887
Problem 1 - Local Server
After the submit button is pressed the address bar address becomes http://localhost/bootstrapelvis/teacupyorkieforsale.php?invalid=true. Because this is a dynamic page none of the information is correct and the database is not updated with the form values.
Problem 2 - website server
teacupyorkieforsale.php is the detail page that is used for all the puppies for sale. This page is called by <?php echo ($row_rsTeacups['DetailPage']); ?>-<?php echo $row_rsTeacups['ProdId']; ?>.html . Then the webconfig file rewrites the URL:
<rule name="Imported Rule 1" stopProcessing="true">
<match url="^([^-]*)-([0-9]+)\.html$" ignoreCase="false" />
<conditions logicalGrouping="MatchAll" trackAllCaptures="false">
<add input="{REQUEST_FILENAME}" matchType="IsDirectory" negate="true" />
<add input="{REQUEST_URI}" pattern="^/(information)" negate="true" />
</conditions>
<action type="Rewrite" url="/teacupyorkieforsale.php?detail={R:1}&amp;Id={R:2}" appendQueryString="false" />
</rule>
So when the submit button is pressed the original address bar url needs to be called. Example the original url is http://www.elvisyorkshireterrier.com/chocolateyorkiepupforsale-193.html after the submit button is pressed the url needs to be http://www.elvisyorkshireterrier.com/chocolateyorkiepupforsale-193.html and not http://www.elvisyorkshireterrier.com/teacupyorkieforsale.php?invalid=true or http://www.elvisyorkshireterrier.com/teacupyorkieforsale.php?Id=193
I don't think it can be coded once to work in both cases but it would be nice is possible. I do need to be able to get to work for both cases so I can test on local server and then rewrite code(if necessary) for it to work on website server.
i think for both problems, you should use:
as the form action for the add to cart foprm and the add to waiting list form:
action="<?php echo ($row_rsTeacups['DetailPage']); ?>-<?php echo $row_rsTeacups['ProdId']; ?>.html">
also, rearange the code so that the validation comes after the rsTeacups recordset, and edit the validation failed redirect:
$WAFV_Redirect = "".(htmlentities($_SERVER["PHP_SELF"], ENT_QUOTES)) ."?invalid=true";
to use the same recordset reference:
$WAFV_Redirect = "".$row_rsTeacups['DetailPage']."-".$row_rsTeacups['ProdId']."?invalid=true";
larry268887
Doesn't work on website haven't checked testing server yet. The browser is now http://www.elvisyorkshireterrier.com/chocolateyorkiepupforsale-193?invalid=true&detail=chocolateyorkiepupforsale&Id=193 and I get a 404 file or directory not found
larry268887
By changing the add to action to the add to cart form causes the add to cart button to not work on the testing server but works on the website server where as the original action code <?php echo $_SERVER["PHP_SELF"]; ?><?php echo (isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] != "")?"?".$_SERVER["QUERY_STRING"]:""; ?> works for both servers.
URL rewriting is really a custom coding scenario, it goes beyond what we can help with thruogh this forum. we could work with you for this in a premiere support appointment:
http://www.webassist.com/premier_request.php
larry268887
On my testing server there is no url rewriting. Lets get that one working.
ok, well then, what is the problem when submitting locally?
larry268887
Went ahead and did a premier support ticket and everything is working great.
