I get a blank page when I use data assist
Thread begun 3/25/2014 4:05 pm by gb261593 | Last modified 3/27/2014 1:49 pm by gb261593 | 5677 views | 10 replies |
gb261593
I have used DA in the past and it's worked fine. Now I am using a very simple search for landlords and/or gender and all I see when I try is a blank page. Before applying Data Assist I could see a list as expected but now even accessing the results page directly shows nothing but I can't see what is stopping the page displaying. Any help gratefully received. (I have attached the two pages.)
a blank page means that a php error is occurring but error reporting is turned off.
to turn error reporting on, add the following code at line 1:
error_reporting
(E_ALL);
once we know what the error is, we will be able to troubleshoot the cause.
gb261593
Thank you. I have done that and got:
Deprecated: mysql_pconnect(): The mysql extension is deprecated and will be removed in the future: use mysqli or PDO instead in /Applications/MAMP/htdocs/acc3/Connections/blac.php on line 9
Fatal error: Call to undefined function setQueryBuilderSource() in /Applications/MAMP/htdocs/acc3/cms/admin/search_advice_results.php on line 57
move this line:
//WA Database Search Include
require_once("../../WADbSearch/HelperPHP.php");
to line 1.
gb261593
Thank you. I now see a listing but if I apply the search it doesn't do any filtering at all - all of the data is listed and I see at the top of the page:
Notice: Undefined variable: WADbSearch1 in /Applications/MAMP/htdocs/acc3/cms/admin/search_advice_results.php on line 62
Notice: Trying to get property of non-object in /Applications/MAMP/htdocs/acc3/WADbSearch/HelperPHP.php on line 381
Notice: Trying to get property of non-object in /Applications/MAMP/htdocs/acc3/WADbSearch/HelperPHP.php on line 395
gb261593
See private message
See PM
gb261593
See PM
see PM
