Page Path Issue with using my User Registration Solution Pack
Thread begun 8/20/2009 6:47 pm by michaelf0199272 | Last modified 8/28/2009 4:42 pm by michaelf0199272 | 2333 views | 1 replies |
michaelf0199272
I am having a problem which prankly has nothing with how the User Registration Solution Pack works. If I may just say, -- User Registration Solution Pack works.
Here is are the facts:
When I was testing out the User Registration Solution Pack -- I uploaded to my hosting server at xceldatatechnologies.com -- This way done just to see if the package worked and it works rather well. But then there is a problem, because of the index.php that I added to the package. Everytime www.xceldatatechnologies.com is launched, index.php was loaded instead of index.html. The reason is because index.php has precedence over index.html.
Well, I said that is not such a problem. I decided to create a directory www.xceldatatechnologies.com /AfricanHeritage/ and I uoloaded all the pages of my African Heritage Register into this directory.
I then purchased anothe domain name www.africanheritage.info which I then had africanheritage/ "masked" forwarded to.
When www.africanheritage.info is launched -- the index.php is loaded from where anyone using the sites will then navigate to all the associated pages.
Here is the problem:
Some of the pages still appear to load from www.xceldatatechnologies.com/ instead from the AfricanHeritage as defined by path --> africanheritage/ --- which is where they should be loading from.
Please review the attached pictures to see what I am saying. Look to the "status" bar at the bottom of the capture to view the path the pages are loading on.
I have contacted Yahoo (my hosting provider). They did not seem to have any clue at least the two support people that I spoke to didn't.
I can force each page to load from the AfricanHeritage directory by simply including it in the links of the navigations. If I did this, it will disable the CSSMenuWriter.
Q1: Does anyone know how I could resovle this problem without disabling CSSMenuWriter???
michaelf0199272
Issue is resolved.
Issue is resolved.
The solution is to re-host site with a different domain name on a completely different server and then upload the website on a fresh account. All the pages are loading just fine.
africanregister.info/ and then forwarded the former africanheritage.info/ to it.
A little expenesive since I now have to use two domain names for one website. But it is the least messy of my options.
*** Now I can finally go ahead and fill it with contents.
Thanks,
Michael
