After adding a product to the cart I receive the following error message "Warning: Cannot modify header information - headers already sent by (output started at /home/greenpe/public_html/Tienda/tienda.php:541) in /home/greenpe/public_html/Tienda/tien
Thread begun 3/25/2014 8:36 am by jspoerer286380 | Last modified 3/27/2014 10:01 am by Jason Byrnes | 2082 views | 3 replies |
jspoerer286380
After adding a product to the cart I receive an error
the following error message "Warning: Cannot modify header information - headers already sent by (output started at /home/greenpe/public_html/Tienda/tienda.php:541) in /home/greenpe/public_html/Tienda/tienda.php
It looks like a PHP error warning... The product is correctly added to the cart but there is no redirection to the cart page...
Any suggestion ?
that error happens becauzse of output on the page before the header function.
the error is saying the proble is around line 541 of the tienda.php page.
if you need further help finding the problem, attach a copy of that page.
NOTE: please use a descriptive title for your posts, don't include the entire message in the tittle filed, that is what the message field is for.
jspoerer286380
Thanks Jason... I found the problem...
Was a space I had in the PHP code... at the end of the "add to cart" code...
I had:
$_SESSION['WAEC_ContinueRedirect'] = $_SERVER['PHP_SELF']."?".$_SERVER['QUERY_STRING'];
else {
$_SESSION['WAEC_ContinueRedirect'] = $_SERVER['PHP_SELF'];
// WA eCart Redirect
if ($greenpeel->redirStr != "") {
header("Location: ".$greenpeel->redirStr);
and it´s has to be:
else {
yes, spaces between php tags will cause the error
