How to replace special characters in file names?
Thread begun 3/25/2014 12:16 am by info4753 | Last modified 6/18/2014 7:56 am by Jason Byrnes | 8804 views | 29 replies |
info4753
It looks like there is no replacement for critical charcters in filename when uploading and saving them to database. I need to replace öüäéèà. How do I achieve this? Thanks for any help
edit the webassist/file_manipulation/helperphp.php
change line 81:
$baseFileName = preg_replace('/\.[^.]*$/', '', $uploadedFile["name"]);
$baseFileName = str_replace(array("ö","ü","ä","é","è","à"), '', $baseFileName);
info4753
Thanks Jason!
you're welcome.
info4753
I'm afraid this doesn't seem to work. I have the following code implemented:
$baseFileName = str_replace(' ', '', $baseFileName);
It removes spaces but not the special characters. Also this is not working:
$baseFileName = str_replace(array(' ',"ö","ü","ä","é","è","à"), '', $baseFileName);
This also removes the spaces in the filename but not the special characters
info4753
Thanks Jason. Pls see pvt section.
see PM
info4753
Done
I corrected the problem by using the following code on the update page:
if(isset($_FILES['Foto'])) {
$_FILES['Foto']['name'] = str_replace(array("ö","ü","ä","é","è","à"," "), '', $_FILES['Foto']['name']);
