Arrgh! One CSSMenuWriter hidden behind another!
Thread begun 3/24/2014 11:05 am by Nathon Jones Web Design | Last modified 3/24/2014 1:24 pm by Jason Byrnes | 4415 views | 7 replies |
I have two CSSMenuWriter occurrences on a page both in separate DIV's. The first menu is always hidden behind the second so that it's obscured.
How do I resolve this?
I've tried manually adding z-index: 999; to each, individually, without success.
Thank you.
please provide a link
i cannot troubleshoot design issues without being able to see them.
Sorry, but I had no option to add a private message when initially writing this post. Details below.
in /CSSMenuWriter/cssmw/menu.css edit the ul#cssmw selector to:
ul#cssmw {
cursor: default;
list-style-type: none;
margin: 0;
padding: 0;
position: relative;
z-index: 999;
That's got it. Is it the "position: relative;" that makes the difference then?
you need both:
position: relative;
z-index: 999;
each position:
position: relative;
or:
position: absolute;
etc
has it's own layer on the page. the z-index property sets the stacking order for the specified layer.
take this as an example, you have 2 dives, one uses:
position: relative;
z-index: 999;
the other uses:
position: absolute;
z-index: 1;
the layer using:
position: absolute;
z-index: 1;
will stack on top of the other since the absolute layer is on top of the relative.
z-index alone makes no difference though, since you don't specify which layer the z-index belongs to.
Really clear. Much appreciated.
you're welcome;.
