Removed UPS Added USPS Shipping
Thread begun 3/24/2014 10:42 am by cal114936 | Last modified 3/28/2014 2:14 pm by Jason Byrnes | 6700 views | 16 replies |
cal114936Beta Tester
Client wants to switch from UPS to USPS. It appears the shipping quote is successful, but the shipping charges are not showing on the confirm_cart.php page. But there are no shipping charges appearing.
eCart 6.05
Dreamweaver CC
Here is part of the result from <?php @session_start(); var_dump($_SESSION); ?>
Thanks,
array(0) { }
array(67) { ["eCart1_Items"]=> string(395) "557|WAECART|XXXXXXXXXXXX - April 2014|WAECART|XXXXXXXX|WAECART|hvw-
001-4-2014_100px.jpg|WAECART|5.6|WAECART|1|WAECART|4.99|WAECART|hvw-001-4-2014|WAECART|7|WAECART|1|
WAECART|139568160414|WAECART|5.6|WAECART|4.99|WAECART|1 XXXXXXXXXXXX - April 2014 (557)"
["WAEC_ContinueRedirect"]=> string(22) "/products.php?hwID=557" ["eCart1_USPS_Success"]=> bool(true)
["eCart1_USPS_SuccessInt"]=> bool(false) ["eCart1_USPS_ResponseCode"]=> int(1) ["eCart1_USPS_Quote"]=> float(2.03)
["eCart1_USPS_QuoteInt"]=> int(0) ["eCart1_USPS_ErrorCode"]=> int(0) ["eCart1_USPS_ErrorDescription"]=> string(0) ""
["eCart1_USPS_FullRequest"]=> string(340) "API=RateV4&XML=FIRST CLASSFLAT926269278206LARGETrue"
["eCart1_USPS_FullResponse"]=> string(471) " 926269278206FLATLARGETRUE1First-Class Mail&lt;sup&gt;&#174;&lt;/sup&gt; Large
Envelope2.03" ["eCart1_USPS_FullRequestInt"]=> bool(false) ["eCart1_USPS_FullResponseInt"]=> string(0) ""
["WASF_CheckoutWizard_Cool_Default"]=> array(33) { ["plugin_from"]=> string(31) "https://XXXXXXXXXXXX/checkout.php" ["plugin_file"]=>
in the cart object, go to the shipping tab.
add a new shipping rule for USPS:
trigger:
Based on USPS Shiping Quote value is > 0
calculation:
Based on USPS Shiping Quote value + 0
Thanks Jason. Should have been able to figure that one. But now I have another.
With USPS want to use First Class, but if weight is over 13 oz we want to use priority. I placed an if statement I found on another thread and under 13 oz it works fine, but I get a failure with priority mail. Dimensions are missing.
["eCart1_USPS_Success"]=> bool(false) ["eCart1_USPS_SuccessInt"]=> bool(false) ["eCart1_USPS_ResponseCode"]=> int(0) ["eCart1_USPS_Quote"]=> int(0) ["eCart1_USPS_QuoteInt"]=> int(0) ["eCart1_USPS_ErrorCode"]=> string(11) "-2147219426" ["eCart1_USPS_ErrorDescription"]=> string(194) "DomesticRatesV4;clsRateV4.ValidateDimension;RateEngineV4.ProcessRequest - Dimensions are missing for package; unable to calculate postage. Additional Info: All dimensions must be greater than 0." ["eCart1_USPS_FullRequest"]=> string(292) "API=RateV4&XML=PRIORITY926269278216LARGETrue" ["eCart1_USPS_FullResponse"]=> string(421) " -2147219426DomesticRatesV4;clsRateV4.ValidateDimension;RateEngineV4.ProcessRequestDimensions are missing for package; unable to calculate postage. Additional Info: All dimensions must be greater than 0.1000440" ["eCart1_USPS_FullRequestInt"]=> bool(false)
I have attached the new confirm_cart page.
ok
Are we getting closer yet?
on line 131 of the confirm cart page, i changed the package size to regular:
$Shipping_PackageArray[$Shipping_PackageIndex]["PackageSize"] = "Regular";
package size large should only be used if you are using your own package, it is used for over sized packages where the shipping is calculated is dimensional weight instead of actual weight.
Jason,
Ok that worked it is now returning a quote for Priority Flat Rate box. The quote returned however is for a Small Flat Rate box even though the Large Flat Rate is specified in the code. It seems to be ignoring the ["PackageType"]= "LG FLAT RATE BOX";
$Shipping_PackageArray[$Shipping_PackageIndex]["PackageType"] = "LG FLAT RATE BOX";
$Shipping_PackageArray[$Shipping_PackageIndex]["PackageMachinable"] = "true";
$Shipping_PackageArray[$Shipping_PackageIndex]["IPackageType"] = "Package";
It also appears weight is affecting the price returned even though its a LG FLAT RATE BOX.
One magazine weighing 5.6oz. in cart large flat envelope is $2.03 - same as USPS website
Two magazines weighing 11.2oz.is $3.08 - same as USPS website
Three magazines weighing 16.8oz triggers Priority mail. Large box specified. Price is for Small box. $5.80
Six magazines weighing 33.6oz returns a new price of $6.50
We'd actually like it to use a Medium Flat Rate box if you could tell me what the "PackageType" should be.
where it is a flat rate box, I wouldn't use USPS Rate lookup, it is waisted trip to to the USPS servers.
just create a shipping rule that if the weifght is above 13oz, use the flat rate charge.
according to the USPS site:
https://store.usps.com/store/browse/uspsProductDetailMultiSkuDropDown.jsp?categoryNavIds=catGetMailingShippingSupplies%3asubcatMSS_PriorityMail&categoryNav=false&navAction=push&navCount=0&productId=P_O_FRB1&categoryId=subcatMSS_PriorityMail
The Domestic Priority Mail rate would be $12.35
so create a flat rate shipping rule for 13.35 above 13 ounces
We also have international orders though....
