google pro maps
Thread begun 3/23/2014 9:33 am by johndewit415187 | Last modified 3/24/2014 1:28 pm by Jason Byrnes | 1673 views | 2 replies |
johndewit415187
google pro maps
Having truoble to see the label, just view the label of the above the location BUT NOT THE TEXT?
see file:///E:/dwfietsen/antpagkoek/brubenshuis.html
can you help me?
Thnak you
John de Wit
this address:
is not a valid web address, it is an address to a page on your local file system
please upload the page to a web site so that i can sere the problem and try to troubleshoot the cause.
This is an issue that will occur when the map is added to a spry tabbed panel.
the map on this page is using the wagmp_map_30 div,
<div id="wagmp_map_30" style="width: 775px; height: 450px;"></div>
To fix the problem, find the following line of code in the google_javascript/wagmp_map_30.js file:
var map = new GMap2(document.getElementById('wagmp_map_1'));
var mapElem = document.getElementById('wagmp_map_1');
var mapWidth = mapElem.style.width;
var mapHeight = mapElem.style.height;
var map = new GMap2(document.getElementById('wagmp_map_1'),{size:new GSize(mapWidth.replace('px',''),mapHeight.replace('px',''))});
