two questions
Thread begun 3/20/2014 12:49 pm by russb335115 | Last modified 3/21/2014 12:35 pm by Jason Byrnes | 4062 views | 9 replies |
russb335115
two questions
1. For the search function/page. Is it possible to have the search (text) field show suggested search results like in the google search function?
2. I set up a featured product section on my home page (that works great). When I click the "shop now" button I want to populate the details page with the product. I have everything working except it populates with the wrong product. Can you help me with this? (I will attached the two files involved)
1) you would need to hand code this with jquery Autocomplete:
http://jqueryui.com/autocomplete/
2) the onclick event on the home page is set to load the products_detail_item.php page, but that is not the page you included
onclick="document.location.href='../products_detail_item.php?ProductID=<?php echo($row_WADAproducts['ProductID']); ?>
<?php echo(isset($_GET["pageNum_WADAproducts"])?"&pageNum_WADAproducts=".intval($_GET["pageNum_WADAproducts"]):""); ?>';"
please send a copy of the products_detail_item.php page.
russb335115
Hi Jason,
Attached is the file. Its based on the theme template so I am using the other two files as plugins.
Also thank you for the link for the query Autocomplete.
russb335115
See pm
It happens when you click "shop now"
i see the problem
in the onclick code:
you are using the WADAproducts recordset to populate the ID, it should be using the WADA_top1_details recordset instead:
onclick="document.location.href='../products_detail_item.php?ProductID=<?php echo($row_WADA_top1_details['ProductID']); ?>';"
russb335115
Wow, I'm a little upset I didn't see that. Thanks for the assistance.
I have another issue with my rotating images on the home page. I created this function with the help os Premier Support and it was working great until this morning. Now the image aren't showing up.
Would you like me to start a new thread for this?
Same site on the home page: http://s403739248.onlinehome.us/drugs123/
The white area should have images that rotate.
theres conflicting versions of jquery on the page
near the top, you include jquery:
<script type='text/javascript' src='plugins/js/jquery.js'></script>
and further down is another reference to jquery form eCart:
<script src="//ajax.googleapis.com/ajax/libs/jquery/1/jquery.min.js"></script>
jquery can only be added once, remove the second one.
russb335115
Awesome, thanks Jason,
Have a great weekend!
you're welcome.
