Problems with wrong details being passed
Thread begun 3/20/2014 4:18 am by dallySP | Last modified 6/08/2018 10:15 am by Ray Borduin | 4711 views | 8 replies |
dallySP
Hi there, you've helped me a lot on this site and my detail page does contain a fair bit of custom coding. I'm having an occasional problem with my add to cart button. Most parameters are passed direct from the items table with the exception of the size and the barcode which come from the inventory table (rsInventory). The InvID is passed to the rsInventory recordset when the customer selects their size (that was your custom coding). This works most of the time, but I've had the odd instance where the wrong barcode and size have been passed and the store has had to contact the customer for confirmation. Could you possible have a look over the detail.php file (attached) and see if you can see any obvious errors. Thanks.
dallySP
See PM
dallySP
  See PM
see pm
anonymous
Originally Said By: dallySP
what if give the right size of the barcode
anonymous
Hi.
Thanks for your nice sharing. I wonder whether it is the latest version of the
Barcode Scanner? I am also looking for a fine barcode scanner whose way of processing is simple and fast to help me scan aztec barcode. It will be better if it offers free trials for users to check. Any suggestion will be appreciated. Thanks in advance.
Best regards,
Pan
anonymous
barcode sdk
  Hi there, you've helped me a lot on this site and my detail page does contain a fair bit of custom coding. I'm having an occasional problem with my add to cart button. Most parameters are passed direct from the items table with the exception of the size and read barcode which come from the inventory table (rsInventory). The InvID is passed to the rsInventory recordset when the customer selects their size (that was your custom coding). This works most of the time, but I've had the odd instance where the wrong barcode and size have been passed and the store has had to contact the customer for confirmation. Could you possible have a look over the detail.php file (attached) and see if you can see any obvious errors. Thanks.
you can try this barcode scan sdk.It supports reading a variety of barcode types, also supports reading multiple different types of barcodes at the same time.
