Database Information Needed
Thread begun 3/19/2014 1:52 pm by VVal62254178 | Last modified 3/20/2014 9:17 am by Jason Byrnes | 1911 views | 3 replies |
VVal62254178
Hi after some time of configuring things I have some products running. The problem is that with the database I don't have the right information in the tables. Isn't there a database for download that contains the correct info?
If there is where do I install it? I ran that cool tool to create a min-server and database on my PC XAMPP
"Isn't there a database for download that contains the correct info?"
Well, the correct info in the database is subjective, it will depend on the needs of your business. We offer a sample database here
http://www.webassist.com/community/tutorials/view_tutorial.php?tid=101
but even this will not be the correct structure for all use cases.
you may need to edit the table structure for the needs of your business.
a business that sells cars will have different needs in the database structure to one that sells cloths or one that sells sporting goods or one that sells music and so on.
VVal62254178
I should have been a little more clear. I cannot proceed because the table information in the database is not complete. I am trying to setup a store that sells apparel.
The database i downloaded where should that be placed? I would like to try a test
on the page that i linked to:
there are instructions for importing the database to the MySQL Server. look in the section titled:
Option 1: Import with phpMyAdmin
and the section titled:
Option 2: Import with another MySQL tool
