Insert Multiple Records
Thread begun 3/19/2014 11:27 am by Daryl | Last modified 3/19/2014 4:26 pm by Jason Byrnes | 2000 views | 3 replies |
DarylBeta Tester
I am trying to complete the managing relational tables tutorial.
I have completed the Update part which is working well however the insert is not.
It appears that the value of the checkboxes is not being added to the database.
In the source code, the checkboxes have a value, however I get the error message - Column 'practitionerClinicClincSlug' cannot be null - which suggests that the value isn't getting taken from the page.
DarylBeta Tester
Hi Jason
Please see below
in the multi record insert, there is a setting for Skip If Empty, you need to select the clinics repeating field in that setting so it will be ignored if not checked.
to fix it, i change:
$WA_insertIfNotBlank = "";
$WA_insertIfNotBlank = "clinics";
