I'm getting a blank screen on www.theonlineclubhouse.com/contactus.php, put error reporting which is telling me webassist/form_validations/wavt_scripts_php.php, every form on this site is coming back with the same error.
Thread begun 3/19/2014 11:06 am by SuperSoaker | Last modified 3/19/2014 12:07 pm by Jason Byrnes | 1370 views | 1 replies |
SuperSoaker
I'm getting a blank screen on www.theonlineclubhouse.com/contactus.php, put error reporting which is telling me webassist/form_validations/wavt_scripts_php.php, every form on this site is coming back with the same error. Fatal error: Call to undefined function virtual() in D:\webspace\millsysadmin\theonlineclubhouse\theonlineclubhouse.com\www\ContactUs.php on line 4
the error:
is happening because of a setting in your dreamweaver site definition.
Dreamweaver is using the "virtual" syntax because in your Site Definition, the "Create Links Relative To:" option is set to Site. If you change that to "Document" instead, Dreamweaver will use the "require_once"syntax.
