sql file for PowerCMS 1
Thread begun 3/18/2014 7:53 am by kelleypb318499 | Last modified 3/18/2014 9:00 am by Jason Byrnes | 3018 views | 5 replies |
kelleypb318499
The sql file for my copy of PowerCMS 1 only contains two tables, "contenthistory" and "contents." Could you provide me with the full executable file so that I may manually set up the database?
those are the only 2 tables needed for PCMS v1.
kelleypb318499
Thanks for replying. The reason I assumed I needed a "wa_settings" table in the database file is because I receive the following error message when I login using the password and username I entered in the WA-Globals.php file under Admin settings:
Warning: strpos() [function.strpos]: Empty delimiter in C:\xampp\htdocs\powercms\CMS\CSSMenuWriter\cssmw\menu.php on line 10
PCMS 1 does not use a WA settings table for the settings, it uses the WA-Globals.php file
in that file, make sure you have the correct settings for the $WAGLOBAL_localRoot and $WAGLOBAL_remoteRoot variables, the error you are getting suggests one or both of those is empty.
from the error:
it looks like the setting for local root should be:
/powercms/CMS/
if you dont have the remote site set up yet, use the same for the remote root.
kelleypb318499
Thank you, that worked!
So is it no longer possible to upgrade to PowerCMS vers. 2?
Power CMS is no longer available as a solution pack.
it is available as part of the design Extender extension.
you would need to purchase Design Extender to get Power CMS 2.
