Is Dreamweaver CS6 Worth it?
I have this problem with this program where it consumes 50% CPU. I tried updating it and it did not work. I uninstalled then reinstalled and still nothing.
Was CS 5.5 better?
Was CS 5.5 better?
personally, I preferred CS5.5 to CS6. But that was not based on CPU usage, I just preferred the usability.
50% CPU usage is very high, I would suggest contacting Adobe Support, it should not be using that much of your CPU
Yes you are correct. I may go to 5.5. Can you explain a few things you liked on it better than 6?
I really just preferred the over all feel of using CS5.5 to using CS6, nothing specific, just felt more comfortable using it.
