I create a contact form, and a insert the email where I want to receive the information
but I dont receive anything, I think that all is perfect created
Who is your host?
Depending on your host, you may need to set certain options in Universal Email.
Some hosts will work if you leave the SMTP Server setting on the Email Server Tab blank, others will require that you enter the SMTP server address.
Some will work using the standard Mail protocol, other will require that you use the Pear Mail for SMTP, some using Pear mail will require authentication.
Some hosts may require that the from address being used be a valid email address for your domain. Some may require that the option to include the from Email address be passed as an extra parameter.
To be successful with Universal Email, you will need to know the requirements of your host for sending an email using a PHP script.
Also, double check your Spam folder, it is possible that the email is being trapped as spam.
I inster the smpt
but I dont receive anytinig
you did not answer any of the questions i asked in my reply.
please re read my initial reply and answer the questions I asked.
Try leaving the SMTP server address and the port number blank, or enter localhost and 25
also, you have the from address set to use a dynamic binding. like i said before, most hosts require the from address to be a valid email address for your domain.
to test the email status, add the following code on the contacts.php page:
<?php @session_start(); var_dump($_SESSION); ?>
this write the session contents to the page including the status of sending the email.
I make all the changes but I still receiving anything
"to test the email status, add the following code on the contacts.php page:
this write the session contents to the page including the status of sending the email."
what does the status on the contacts page say?
array(9) { ["WAVT_contacts_Errors"]=> string(0) "" ["waue_contacts_1_Status"]=> string(7) "Success" ["waue_contacts_1_Index"]=> int(1) ["waue_contacts_1_From"]=> string(26) "jjimenez@sjwebdesignpr.com" ["waue_contacts_1_To"]=> string(22) "info@sjwebdesignpr.com" ["waue_contacts_1_Subject"]=> string(8) "Contatco" ["waue_contacts_1_Body"]=> string(3849) " --WAMULTIBREAKWA Content-Type: text/plain Content-Transfer-Encoding: 8bit Your Email Title Goes Here email subtitle area or directions can go here, below the title Form Submitted: 3-17-2014 | 1:50 PM EDT First Name: Javier Last Name: Jimenez Phone Number: (787) 510-5518 Email Address: jjimenez@tekpropr.com fieldset group Comment: Prueba Default submit: Send --WAMULTIBREAKWA Content-Type: text/html
First Name: Javier
Last Name: Jimenez
--WAMULTIBREAKWA-- " ["waue_contacts_1_Header"]=> string(360) "MIME-Version: 1.0 Content-Type: multipart/alternative; boundary="WAMULTIBREAKWA" From: jjimenez@sjwebdesignpr.com Reply-To: jjimenez@sjwebdesignpr.com Return-Path: jjimenez@sjwebdesignpr.com X-Sender: jjimenez@sjwebdesignpr.com X-Priority: 1 Date: Mon, 17 Mar 2014 13:50:34 -0400 (EDT) Message-ID: <69751611.62654955b6e11bc5b84ba546681162c3@sjwebdesignpr.com> " ["waue_contacts_1_Log"]=> string(51) "Sending To: info@sjwebdesignpr.com... Success
the status says success:
so you should contact your host to determine why the emails is not being relayed by the SMTP server.
