Problems with other extensions after installing WA extensions
Thread begun 3/17/2014 3:30 am by info4753 | Last modified 4/04/2014 10:20 am by Jason Byrnes | 4877 views | 14 replies |
info4753
With the newsest installation routine, I have problems running other extension along with WA extensions. Mostly DMXZone extension seems to stop working. They say that it's a problem of WA. Do you have any knowledge of this issue?
The problem occurs under DW CC Mac
Yes, we are aware of a problem with the DMX zone extensions.
eCart 6.0.5 has already been updated to correct the problem, and we will be releasing updates to Design Extender and Data Bridge shortly.
info4753
Thanks Jason.
Any news on the next mayor WA updates and/or roadmap? Wainting for this since last November ;-)
No, there is no news at this time.
when the road map is available, we will be sending out an email with that information.
info4753
ok, thanks
info4753
Has the problem been fixed with the newset version of Data Bridge?
Yes, this issue is fixed in Data Bridge 1.1.9
info4753
Thanks Jason.
What about Design Extender? This one is still not fixed, right?
design extender has not been fixed, but if you install it, open DW to run the webAssist installer, then install either eCart 6.0.6, free tools 1.0.9 or Data Bridge 1.1.9 it will over write the file created by the design extender installation that has the problem thus installing the fix.
info4753
Do I have to do this before or after installing DMXZone extensions? And what do I have to do if I want to install another DMXZone extension or an update after the installion of the WA extensions?
