JavaScript error while loading Dyn TextField.htm
Thread begun 3/14/2014 6:45 am by phill401410 | Last modified 3/14/2014 12:43 pm by phill401410 | 6508 views | 4 replies |
phill401410
Here is an interesting one. I get the following errors when working on the attached file, spinner_rex.php, on my desktop machine using DW CS5.5 0n Windows 7:
The DynTextField script does not define the findServerBehaviors function.
OR
JavaScript error while loading Dyn TextField.htm:
At line 54 of file "C\Progam Files(x86)\Adobe\Adobe Dreamweaver CS5.5\Configuration\Shared\Controls\Scripts\TagMenu.js":
The user chose to stop the script.
OR
A script in file C:\Program Files (x86)\Adobe\Adobe Dreamweaver CS5.5\Configuration\Shared\Controls\Scripts\TagMenus.js has been running for a long time. Do you want to continue?
I deleted WinFileCache-9287E01C.dat but still throws errors.
I do not get the above errors on spinner_rex.php on my laptop machine using DW CS5.5 0n Windows 8. I have Data Bridge 1.1.8 and eCart 5.0.7 (planning on installing eCart 6.0 soon) on the desktop machine that throws the errors but no extensions loaded on laptop.
Perhaps this is unrelated but when I open DW CS5.5 on the desktop machine I get two error messages: Unable to find file WA_Memento.htm in the Configurations/Floaters directory. The floater will not be shown and Unable to find file WA_SiteTools_Progress.htm in the Configurations/Floaters directory. The floater will not be shown.
Annoying but not life threatening issues. Thank you as always.
What extensions other than eCart and data bridge are installed, please include version numbers?
have you tried:
reset the workspace layout:
go to Window -> Work Space layout -> Reset '<your layout name>'
and Delete the Dreamweaver Cache file from the users configuration folder:
phill401410
Jason
Reset the Workspace Layout - no luck.
I deleted WinFileCache-9287E01C.dat again but still throws errors.
Extensions:
Only running WA Data Bridge 1.1.8 and eCart 5.0.7 but have these others:
jQuery OnePage v1.0.10
concrete5 Theme Snippets v5.3.2
CMXzone Feed Ticker v1.0.4
DMXzone Updater v1.6.1
RSS DreamFeeder v2.5.2
MINIPlayer v1.1.0
Zoom Search Engine v6.0.10
jQuery SlideshowPlus for Dreamweaver v1.0.3.2
Thank you.
try recreating the users configuration folder:
http://helpx.adobe.com/dreamweaver/kb/troubleshoot-javascript-errors-dreamweaver-cs4.html#main_user_config
then reinstalling the extensions.
when installing the WebAssist extensions, install eCart, then Data Bridge.
phill401410
Thanks Jason
running through steps on http://helpx.adobe.com/dreamweaver/kb/troubleshoot-javascript-errors-dreamweaver-cs4.html#main_user_config
