WA_Persistent_Forms.htm error on dreamweaver startup
Thread begun 3/14/2014 5:55 am by asarcona308398 | Last modified 4/11/2014 8:24 am by codamedia | 6137 views | 17 replies |
asarcona308398
Hey guys,
I'm running DW CS5 on WIN7 64bit
I updated eCart and re-installed DB and DE and this error comes in on opening DW.
I have deleted the cache file and re-started the computer... doesn't go away!
Thanks.
Tony
asarcona308398
Seems to be resloved...
I had the free tools 1.0.8 installed,
I removed it and added the new free tools and error seems to be resolved... maybe an issue with the new DB or DE??
Ok, glad to hear it is working.
asarcona308398
Actually....Not resolved..
Hey Jason,
It seems after shutting down the box and starting the next day error returns, and even with cache deletion doesn't go away.
It has been Persistent everyday since...(no pun intended!)
Any thoughts?
Thanks,
Tony
try uninstalling eCart the installing it again.
also try using the OS file system browser, browse to your DW Site root and delete the _notes folder.
asarcona308398
No Results..
Deleted cache, _notes --- un-install - re-install eCart .... no good... What the script is referencing??
Can we test to see if the script is still working regardless of the error warning?
Didn't have this error prior to new eCart
If you need a Remote session let me know
Thanks. Tony
asarcona308398
Well This Is Odd ...
I re-cycled the box and the error has gone away... possible activation conflict on dreamweaver start...
might need a sleeper for a second for dependent files to load first???
Just a guess,
Well it seems to be OK,
If you want to investigate any logs or such for records of failure let me know,
Thanks,
Tony
Glad to hear it is working now. If the error comes back let us know, include a phone number or skype address and we can contact you to do a screen sharing session to investigate the cause.
asarcona308398
see pm
Is the error back again?
We will only be able to troubleshoot if the error is occurring.
