Redirect after logout to different page depending on user group?
Thread begun 3/13/2014 3:49 pm by Mags | Last modified 3/17/2014 7:41 am by Jason Byrnes | 2289 views | 3 replies |
Mags
We have three user groups set up on our system, two of which are actually different companies. I would like to be able to redirect users to a different page (on an external site) depending on the user group they belong to - so for example, Usergroup A (our company) logs out and gets redirected back to our homepage; Usergroup B (external company) logs out and is redirected back to their own company's homepage. Is this possible?
it would require hand coding to evaluate the user group and set a variable with the log out:
Assuming the user group is stored in a session named UserGroup, you could use cold like this on the logout page before the code block to unset the session variables:
@session_start();
switch ($_SESSION['UserGroup']) {
case "a":
$redir = "page1.php";
break;
case "b":
$redir = "page2.php";
break;
case "c":
$redir = "page3.php";
break;
default:
$redir = "default.php";
and this to do the redirect after the code to unset the sessions:
header("Location: ".$redir); ?>
http://www.php.net/manual/en/control-structures.switch.php
Mags
Thanks Jason, as it turns out I don't need to do this now, but will bear it in mind in case they change their minds at some point - and your reply may help other users in the meantime.
You're welcome.
