data assist multiple deletes script leaving ?> when re-entered a second time ...
Thread begun 3/13/2014 9:19 am by asarcona308398 | Last modified 3/13/2014 12:52 pm by Jason Byrnes | 3025 views | 7 replies |
asarcona308398
Hey guys,
I've noticed a bug when re-entering delete multiple records server behavior
the script will give you this the first time out:
// WA DataAssist Multiple Deletes
if (isset($_POST["Delete"]) || isset($_POST["Delete_x"])) // Trigger
$WA_loopedIDField = array("WADA_RepeatID_id");
$WA_loopedField = array("WADA_RepeatID_id");
$WA_connection = $conn_studiogear_mgr;
$WA_table = "sg_music_recital";
$WA_redirectURL = "?id=".((isset($_POST["WADADeleteRecordID"]))?$_POST["WADADeleteRecordID"]:"") ."";
if (function_exists("rel2abs")) $WA_redirectURL = $WA_redirectURL?rel2abs($WA_redirectURL,dirname(__FILE__)):"";
$WA_keepQueryString = false;
$WA_indexField = "recital_id";
$WA_columnTypesStr = "none,none,NULL";
$WA_fieldNames = explode("|", $WA_indexField);
$WA_comparisions = array("=");
$WA_connectionDB = $database_conn_studiogear_mgr;
$WA_multipleDeleteCounter = 0;
while (WA_AB_checkLoopedFieldsNotBlank($WA_loopedIDField, $WA_multipleDeleteCounter)) {
if (WA_AB_getLoopedFieldValue($WA_loopedIDField[0], $WA_multipleDeleteCounter) == WA_AB_getLoopedFieldValue($WA_loopedField[0], $WA_multipleDeleteCounter)) {
$WA_fieldValuesStr = WA_AB_getLoopedFieldValue($WA_loopedIDField[0], $WA_multipleDeleteCounter);
$WA_fieldValues = array($WA_fieldValuesStr);
$deleteParamsObj = WA_AB_generateWhereClause($WA_fieldNames, $WA_columns, $WA_fieldValues, $WA_comparisions);
$WA_Sql = "DELETE FROM `" . $WA_table . "` WHERE " . $deleteParamsObj->sqlWhereClause;
$WA_multipleDeleteCounter++;
if ($WA_redirectURL != "") {
BUT then if re-entering the behavior, this is written to the page:
the trailing ?> is extra and will show on the page at the top, if you go in and out many times... the ?> will repeat every time!
Tony
I am not able to reproduce this using Data Bridge 1.1.8, Dreamweaver CC on Mac OS
please provide some additional details on the Data Bridge version you are using, your DW version, and OS.
asarcona308398
Jason,
see attached
Tony
Im not able to reproduce with Windows 7 and DW CS5 either
Just a note:
some of the extensions you have installed are either outdated or Discontinued
eCart 5.0.3 -> Replaced by 5.0.7
Surveyor -> Discontinued
Bind Search -> The Bing v1 service is no longer available, it was replaced by Bing v2 which is now a paid for service
Theme-It -> this conflicts with Them-It in DE and DB
WebStandards -> Discontinued
Photo Assist -> Discontinued / not compatible with DW CS5
uninstall the discontinued extensions, update eCart, then uninstall and reinstall Data Bridge
asarcona308398
Jason,
thanks for the tips, I will do that
Thanks,
Tony
you're welcome.
asarcona308398
Jason,
Did as said, and except for having to delete cache file, seems to be resolved
Thanks,
Tony
glad to hear it is working.
