Level 1 two different sizes?
Thread begun 3/13/2014 7:18 am by Nathon Jones Web Design | Last modified 3/13/2014 10:10 am by Jason Byrnes | 3957 views | 9 replies |
I changed Level 1 in our menu to use a 250px graphic. I updated the Level 1 width in the stylesheet manually, because if I use the wizard it overwrites the vertical alignment settings we previously hand coded <sigh>, but it didn't work so I went into the wizard and changed it and it still hasn't updated. What gives?
If you check the following link, the Spot Lights menu is different to the Flood Lights menu:
http://www.ledwarehouseuk.com/indexHOME.php
I'm not sure how that's even possible.
Hope you can help. Thank you.
NJ
in your css for the level 1 menu item, change display: table-cell; to display: block;
You'd previously advised me to use display: table-cell; because I wanted the text middle aligned (vertically)?
Here's the Level 1 CSS which already has display: block:
ul#cssmw ul.level-1 > li > a, ul#cssmw ul.level-1 > li > a:link {
background-image: url("../cssmw_images/btn-mainnav-sub1off.png");
background-repeat: no-repeat;
color: #FFFFFF;
display: block;
font-family: "myriad pro", Arial, Helvetica, sans-serif;
font-size: 16px;
font-style: normal;
font-weight: bold;
height: 65px;
margin: 0 0 0 0;
padding: 0 5px 0 10px;
text-align: left;
text-decoration: none;
width: 235px;
outline-style: none;
vertical-align: middle;
Can you please advise?
Thanks man.
NJ
I have changed this to the following:
color: #FFFFFF;
display: block;
font-size: 16px;
font-style: normal;
font-weight: bold;
height: 65px;
margin: 0 0 0 0;
text-align: left;
width: 235px;
display: block;
So now we have 2 occurences of display: block; but, in doing so, it has removed the middle (vertical) align (see "Commercial & Street Lighting" menu).
NJ
you don't need to have 2 instances of the display, there should only be one.
also, you have:
text-align: left;
you cannot have both align left and align center, the text align setting is over riding the vertical align setting.
Confusion?
In a previous post Jason, I'd asked you how vertically align text in CSSMenuWriter and you had advised that I add:
It worked like a charm. The text was BOTH left align (horizontally) and middle aligned (vertically).
I've removed text-align:left; from the CSS but now all my text is centred, which isn't what I want.
The problem I was having was that the width settings didn't seem to be being picked up.
My menu is now all over the place:
...although thankfully it HAS picked up the width settings now.
How do I both left align AND middle align the text?
Thank you.
NJ
Confusion is correct, your question, initially, was not clear to me.
add text-align: left; back in , and add:
line-height: 65px;
Phweeff! We got there! :)
Is there any way of saving these settings as a template in CSSMenuWriter?
If I open up the wizard and make any changes to the theme it just overwrites everything. :(
no, there is not a way to save these settings to menu writer.
create a new css file with these changes in it, and attach that css file after the menu writer one, so that your changes will over ride what is generated by the wizard.
