DataAssist Pages Wizard Aborts
Thread begun 3/12/2014 11:41 am by dhagood355349 | Last modified 3/13/2014 11:11 am by Jason Byrnes | 5535 views | 18 replies |
dhagood355349
I've been trying to run the DataAssist Pages Wizard for two days now. I've tried in Win7 and Win 8 on DwCC and version 5.5. I've used every little hint here and it still aborts. I've done it multiple machines.
Is there a fix or patch for these aborts?
please provide some additional details.
what settings are you using in the wizard?
at what point does it crash?
are you using one of the application presets?
Are you using your own table?
if using your own table, what is the table structure?
Also, what version of data Bridge is installed? make sure you have the latest version, 1.1.8.
dhagood355349
WebAssit
what settings are you using in the wizard? Default Settings
at what point does it crash? At different points but when I'm on Manage Pages, select Define Features, Add the features then hit OK. This when it aborts and aborts Dreamweaver
are you using one of the application presets? just turned off preview
Are you using your own table? Yes, using lowercase no spaces or _
Field Name Field Type Size Precision Not Null Unsigned AutoInc Default Description
News_id INTEGER 11 0 Not Null False True Null
Date TEXT 0 0 False False Null
Category VARCHAR 30 0 False False Null
Circuit VARCHAR 255 0 False False Null
Division INTEGER 3 0 False False Null
EventID INTEGER 11 0 False False Null
Author VARCHAR 50 0 False False Null
Title TEXT 0 0 False False Null
Lead LONGBLOB 0 0 False False Null
Body LONGBLOB 0 0 False False Null
Display VARCHAR 3 0 False False N
Also, what version of data Bridge is installed? make sure you have the latest version, 1.1.8. yes using the latest for CC
Thanks for the assistance!
dhagood355349
Webassist Crash
Adding a Screen Shot
These answers are not very clear.
"are you using one of the application presets? just turned off preview"
I wasnt asking about the preview. I was asking on the "Page Settings" tab, have you selected one of the application presets? or selected "New Form Blank"
Also, you say
"Are you using your own table? Yes, using lowercase no spaces or _"
but then the first column name is using upper case and the underscore:
News_id
Please provide a Skype username or a US phone number and a good time to contact you when you will be in front of your computer and we will have an engineer contact you to resolve this issue over the phone.
We are available Monday - Friday from 9am - 4pm EST (except major U.S. holidays).
dhagood355349
Issue with DataAssist Wizard
I removed the _ in the table and the wizard did not crash.
I completed it using defaults just to test it out. I uploaded the pages and tested the insert page.
When you select Insert (button) it does nothing. Doesn't write to the DB or advance to the Results page or show any error?
dhagood355349
DataAssist
See Private
see PM
dhagood355349
DataAssist
See Private
