post data to Database, over write !
Thread begun 3/11/2014 2:53 am by Salah Heddad | Last modified 3/12/2014 8:34 am by Jason Byrnes | 2113 views | 4 replies |
Salah Heddad
hello
would you please help with this;
This number 2147483647 overwrite any data posted for only one column,
for example:
if i post 123456789123 when i go to my database i found this number 2147483647 posted instead of what i inserted from my insert page!
Salah Heddad
maybe it is not the right way but somehow it is works;
just changed data type from integer to none and in the database change it to varchar! ...
the maximum value that an integer column can contain when it is is set to unsigned is:
2147483647
So using the integer type is the problem as you already discovered, see this page for more details:
http://dev.mysql.com/doc/refman/5.0/en/integer-types.html
Salah Heddad
Thanks Mr, Jason for your care
you're welcome.
