Sandbox Access
Thread began 3/10/2014 11:54 am by Mike Perry | Last modified 3/10/2014 1:28 pm by Mike Perry | 637 views | 7 replies |
Mike Perry
Sandbox Access
I have the necessaey PayPal accounts set up (Business & Personal). I have the business APIs entered in the Gateway Credentials, Test Mode on, and debug off.
When I click on the Continue button on confirm.php it fails to rediect to Paypal. I don't even see the paypal.com reference in the status toolbar.
Does this mean that Paypal is having a problem with the credentials, or that the redirect to paypal isn't processing for some reason??
Thanks,
Mike
make sure that you are using eCart 6.0.5 to create the checkout pages.
add the following code to the failure page to determine write the session contents:
<?php @session_start(); var_dump($_SESSION); ?>
this will include the response from paypal to help determine the cause of the problem.
Mike Perry
That may be the problem -- not sure which version I used to create.
Save the old ones and redo!!
Will advise. . .
delete the old ones and recreate using 6.0.5.
Mike Perry
I meant for backup to handle any custom code. . .
Mike Perry
Jason -- I reinstalled all my WA extensions.
In the attached pp_confirm.php file there is a syntax error indicated by DW at line 159. I have not modified the files in any way. . .
Thoughts??
in the store order summary you are using recordset bindings that don't exist.
the error is coming from the settings used for the OrderShipName column you should not be using recordset bindings.
When running the checkout wizard, use one of the presets from the orders tab.
Mike Perry
Forgot to add the Recordset . . .
Duh.. . .
