Duplicate code problem? Done nothing other than use eCart wizards.
Thread begun 3/10/2014 8:16 am by Nathon Jones Web Design | Last modified 3/10/2014 10:40 am by Jason Byrnes | 2224 views | 3 replies |
I've used the eCart wizards and dialogue boxes but, upon checking my code (with my limited knowledge of PHP I would add), I can't help but feel that there is a lot of duplication which I'm concerned will cause errors. Here's my shopping basket page...
error_reporting(E_ALL);
<?php require_once('Connections/njMySQL.php'); ?>
//WA eCart Include
require_once("WA_eCart/LEDCart_PHP.php");
$LEDCart->GetContent();
if (PHP_VERSION < 6) {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
$colname_rsPROD = "-1";
if (isset($_GET['lbid'])) {
$colname_rsPROD = $_GET['lbid'];
mysql_select_db($database_njMySQL, $njMySQL);
$query_rsPROD = sprintf("SELECT LEDid, LEDtitle, LEDtitlemeta, LEDdesc, LEDmetadesc, LEDproductcode, LEDtypeID, LEDtypename, LEDtypeURL, LEDbaseID, LEDbasename, LEDstyleID, LEDstylename, LEDwattage, LEDcolourID, LEDdimmable, LEDcover, LEDlumens, LEDbrightness, LEDbeamangle, LEDsensor, LEDnoofchips, LEDprice, LEDnetweight, LEDwidth, LEDheight, LEDvoltage, LEDacdc, LEDreplacementfor, LEDavglife, LEDcerohs, LEDimgtmb, LEDimg, LEDimg1, LEDimg2, LEDimg3, LEDdelete, LEDoffer FROM qryLEDallprods WHERE LEDid = %s", GetSQLValueString($colname_rsPROD, "int"));
$rsPROD = mysql_query($query_rsPROD, $njMySQL) or die(mysql_error());
$row_rsPROD = mysql_fetch_assoc($rsPROD);
$totalRows_rsPROD = mysql_num_rows($rsPROD);
$paramItem_rsCOLOUR = "-1";
if (isset($row_rsPROD['LEDid'])) {
$paramItem_rsCOLOUR = $row_rsPROD['LEDid'];
$query_rsCOLOUR = sprintf("SELECT LEDprodoptions.LEDprodoptionincr, LEDprodoptions.LEDprodoptionsID, LEDvars.LEDvarname, LEDvars.LEDprodvarID, LEDprodvars.LEDprodvarname FROM LEDvars INNER JOIN LEDprodoptions ON LEDvars.LEDvarID = LEDprodoptions.LEDvarID INNER JOIN LEDprodvars ON LEDvars.LEDprodvarID = LEDprodvars.LEDprodvarID WHERE LEDprodvars.LEDprodvarname = 'Colour' AND LEDprodoptions.LEDid = %s", GetSQLValueString($paramItem_rsCOLOUR, "int"));
$rsCOLOUR = mysql_query($query_rsCOLOUR, $njMySQL) or die(mysql_error());
$row_rsCOLOUR = mysql_fetch_assoc($rsCOLOUR);
$totalRows_rsCOLOUR = mysql_num_rows($rsCOLOUR);
$paramItem_rsDIMM = "-1";
$paramItem_rsDIMM = $row_rsPROD['LEDid'];
$query_rsDIMM = sprintf("SELECT LEDprodoptions.LEDprodoptionincr, LEDprodoptions.LEDprodoptionsID, LEDvars.LEDvarname, LEDvars.LEDprodvarID, LEDprodvars.LEDprodvarname FROM LEDvars INNER JOIN LEDprodoptions ON LEDvars.LEDvarID = LEDprodoptions.LEDvarID INNER JOIN LEDprodvars ON LEDvars.LEDprodvarID = LEDprodvars.LEDprodvarID WHERE LEDprodvars.LEDprodvarname = 'Dimmable' AND LEDprodoptions.LEDid = %s", GetSQLValueString($paramItem_rsDIMM, "int"));
$rsDIMM = mysql_query($query_rsDIMM, $njMySQL) or die(mysql_error());
$row_rsDIMM = mysql_fetch_assoc($rsDIMM);
$totalRows_rsDIMM = mysql_num_rows($rsDIMM);
$paramOption_rsDIMMLOOKUP = "-1";
if (isset($_POST['LEDCart_1_Dimmable_Add'])) {
$paramOption_rsDIMMLOOKUP = $_POST['LEDCart_1_Dimmable_Add'];
$paramItem_rsDIMMLOOKUP = "-1";
if (isset($_POST['LEDCart_1_ID_Add'])) {
$paramItem_rsDIMMLOOKUP = $_POST['LEDCart_1_ID_Add'];
$query_rsDIMMLOOKUP = sprintf("SELECT LEDprodoptions.LEDprodoptionincr, LEDprodoptions.LEDprodoptionsID, LEDvars.LEDvarname, LEDvars.LEDprodvarID, LEDprodvars.LEDprodvarname FROM LEDvars INNER JOIN LEDprodoptions ON LEDvars.LEDvarID = LEDprodoptions.LEDvarID INNER JOIN LEDprodvars ON LEDvars.LEDprodvarID = LEDprodvars.LEDprodvarID WHERE LEDprodvars.LEDprodvarname = 'Dimmable' AND LEDprodoptions.LEDprodoptionsID = %s AND LEDprodoptions.LEDid = %s", GetSQLValueString($paramOption_rsDIMMLOOKUP, "int"),GetSQLValueString($paramItem_rsDIMMLOOKUP, "int"));
$rsDIMMLOOKUP = mysql_query($query_rsDIMMLOOKUP, $njMySQL) or die(mysql_error());
$row_rsDIMMLOOKUP = mysql_fetch_assoc($rsDIMMLOOKUP);
$totalRows_rsDIMMLOOKUP = mysql_num_rows($rsDIMMLOOKUP);
$paramOption_rsCOLOURLOOKUP = "-1";
if (isset($_POST['LEDCart_1_Colour_Add'])) {
$paramOption_rsCOLOURLOOKUP = $_POST['LEDCart_1_Colour_Add'];
$paramItem_rsCOLOURLOOKUP = "-1";
$paramItem_rsCOLOURLOOKUP = $_POST['LEDCart_1_ID_Add'];
$query_rsCOLOURLOOKUP = sprintf("SELECT LEDprodoptions.LEDprodoptionincr, LEDprodoptions.LEDprodoptionsID, LEDvars.LEDvarname, LEDvars.LEDprodvarID, LEDprodvars.LEDprodvarname FROM LEDvars INNER JOIN LEDprodoptions ON LEDvars.LEDvarID = LEDprodoptions.LEDvarID INNER JOIN LEDprodvars ON LEDvars.LEDprodvarID = LEDprodvars.LEDprodvarID WHERE LEDprodvars.LEDprodvarname = 'Colour' AND LEDprodoptions.LEDprodoptionsID = %s AND LEDprodoptions.LEDid = %s", GetSQLValueString($paramOption_rsCOLOURLOOKUP, "int"),GetSQLValueString($paramItem_rsCOLOURLOOKUP, "int"));
$rsCOLOURLOOKUP = mysql_query($query_rsCOLOURLOOKUP, $njMySQL) or die(mysql_error());
$row_rsCOLOURLOOKUP = mysql_fetch_assoc($rsCOLOURLOOKUP);
$totalRows_rsCOLOURLOOKUP = mysql_num_rows($rsCOLOURLOOKUP);
$paramItem_rsSENSOR = "-1";
$paramItem_rsSENSOR = $row_rsPROD['LEDid'];
$query_rsSENSOR = sprintf("SELECT LEDprodoptions.LEDprodoptionincr, LEDprodoptions.LEDprodoptionsID, LEDvars.LEDvarname, LEDvars.LEDprodvarID, LEDprodvars.LEDprodvarname FROM LEDvars INNER JOIN LEDprodoptions ON LEDvars.LEDvarID = LEDprodoptions.LEDvarID INNER JOIN LEDprodvars ON LEDvars.LEDprodvarID = LEDprodvars.LEDprodvarID WHERE LEDprodvars.LEDprodvarname = 'Sensor' AND LEDprodoptions.LEDid = %s", GetSQLValueString($paramItem_rsSENSOR, "int"));
$rsSENSOR = mysql_query($query_rsSENSOR, $njMySQL) or die(mysql_error());
$row_rsSENSOR = mysql_fetch_assoc($rsSENSOR);
$totalRows_rsSENSOR = mysql_num_rows($rsSENSOR);
$paramOption_rsSENSORLOOKUP = "-1";
if (isset($_POST['LEDCart_1_Sensor_Add'])) {
$paramOption_rsSENSORLOOKUP = $_POST['LEDCart_1_Sensor_Add'];
$paramItem_rsSENSORLOOKUP = "-1";
$paramItem_rsSENSORLOOKUP = $_POST['LEDCart_1_ID_Add'];
$query_rsSENSORLOOKUP = sprintf("SELECT LEDprodoptions.LEDprodoptionincr, LEDprodoptions.LEDprodoptionsID, LEDvars.LEDvarname, LEDvars.LEDprodvarID, LEDprodvars.LEDprodvarname FROM LEDvars INNER JOIN LEDprodoptions ON LEDvars.LEDvarID = LEDprodoptions.LEDvarID INNER JOIN LEDprodvars ON LEDvars.LEDprodvarID = LEDprodvars.LEDprodvarID WHERE LEDprodvars.LEDprodvarname = 'Sensor' AND LEDprodoptions.LEDprodoptionsID = %s AND LEDprodoptions.LEDid = %s", GetSQLValueString($paramOption_rsSENSORLOOKUP, "int"),GetSQLValueString($paramItem_rsSENSORLOOKUP, "int"));
$rsSENSORLOOKUP = mysql_query($query_rsSENSORLOOKUP, $njMySQL) or die(mysql_error());
$row_rsSENSORLOOKUP = mysql_fetch_assoc($rsSENSORLOOKUP);
$totalRows_rsSENSORLOOKUP = mysql_num_rows($rsSENSORLOOKUP);
// WA eCart AddToCart
if (isset($_POST["LEDCart_1_ATC"]) || isset($_POST["LEDCart_1_ATC_x"])) {
$ATC_itemID = $_POST["LEDCart_1_ID_Add"];
$ATC_AddIfIn = 0;
$ATC_RedirectAfter = "shopping-basket.php";
$ATC_RedirectIfIn = "";
if (isset($totalRows_rsPROD) && $totalRows_rsPROD > 0) {
$row_rsPROD = WAEC_findRecordMySQL($rsPROD, "LEDid", $ATC_itemID);
if ($row_rsPROD) {
$ATC_itemName = "".$row_rsPROD['LEDproductcode'] ."";// column binding
$ATC_itemDescription = "".$row_rsPROD['LEDtitle'] ."";// column binding
$ATC_itemThumbnail = "".$row_rsPROD['LEDimg'] ."";// column binding
$ATC_itemWeight = floatval("".$row_rsPROD['LEDnetweight'] ."");// column binding
$ATC_itemQuantity = "".$_POST["LEDCart_1_Quantity_Add"] ."";// column binding
$ATC_itemPrice = floatval("".$row_rsPROD['LEDprice'] ."");// column binding
$ATC_itemColour = "".$_POST["LEDCart_1_Colour_Add"] ."";// column binding
$ATC_itemDimmable = "".$row_rsDIMMLOOKUP['LEDvarname'] ."";// column binding
$ATC_itemDimmPriceInc = floatval("".$row_rsDIMMLOOKUP['LEDprodoptionincr'] ."");// column binding
$ATC_itemSensor = "".$_POST["LEDCart_1_Sensor_Add"] ."";// column binding
mysql_data_seek($rsPROD, 0);
$ATC_itemQuantity = floatval($ATC_itemQuantity);
if (is_numeric($ATC_itemQuantity) && $ATC_itemQuantity != 0) {
$LEDCart->AddToCart($ATC_AddIfIn, $ATC_RedirectIfIn, $ATC_itemID, $ATC_itemName, $ATC_itemDescription, $ATC_itemThumbnail, $ATC_itemWeight, $ATC_itemQuantity, $ATC_itemPrice, $ATC_itemColour, $ATC_itemDimmable, $ATC_itemDimmPriceInc, $ATC_itemSensor);
if ($ATC_RedirectAfter != "" && $LEDCart->redirStr == "") {
$LEDCart->redirStr = $ATC_RedirectAfter;
if (isset($_SERVER['QUERY_STRING']) && $_SERVER['QUERY_STRING'] != "") {
$_SESSION['WAEC_ContinueRedirect'] = $_SERVER['PHP_SELF']."?".$_SERVER['QUERY_STRING'];
else {
$_SESSION['WAEC_ContinueRedirect'] = $_SERVER['PHP_SELF'];
// WA eCart Redirect
if ($LEDCart->redirStr != "") {
header("Location: ".$LEDCart->redirStr);
Can someone help me make sense of (strip down!) the above and also explain why eCart is inserting duplicate content like this?
With ASP/VBScript I had a reasonable understanding of what all this meant but I'm terrified of changing anything in the PHP for fear of wrecking a script.
Thank you.
NJ
the only duplication is see is the GetSQLValueString() function decelaration
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
you can remover the second instance of the GetSQLValueString() function.
every thing else is the 7 recordsets on the page and the add to c art button code.
the GetSQLValueString() function is defined by Dreaweaver.
sometimes Dreamweaver doesn't recognize that the function is already there and will add a duplicate when you are working on recordsets. It wont hurt anything to leave the duplicate in place.
Thanks Jason. Have removed that.
Dreamweaver 8.0.2 used to do this with my ASP/VBScript stuff but I, incorrectly, assumed that this would be all 'fixed' in DWCC so, therefore, assumed it was eCart at fault.
Thank you for clarification.
Regards
NJ
you're welcome.
