WA_DigitalFilePro
Thread began 3/08/2014 8:13 am by neel357205 | Last modified 3/12/2014 10:19 am by Jason Byrnes | 1253 views | 4 replies |
neel357205
WA_DigitalFilePro
I've added the file upload behaviour to a form. Form data is being inserted into SQL table but image file name is not being stored. One potential issue is that I need to upload ../WA_DigitalFilePro/HelperPHP.php.
Unfortunately these files have not been copied into my site folder. Where can I get them from?
attached is a copy of the WA_DigitalFilePro/HelperPHP.php file.
if you need further help, send a copy of the form page.
HelperPHP.php
neel357205
Please see attached file
to troubleshoot the probelm
1) edit line 133:
//header("Location: ".$WA_redirectURL);
2) add the following code at line 1:
error_reporting(E_ALL);
and add this code just before the </body> tag:
if (isset($_POST["Insert"]) || isset($_POST["Insert_x"])) {
echo("insert SQL: ".$WA_Sql);
echo("<pre>");
var_dump($_FILES);
echo("</pre>");
echo WA_DFP_AllUploadsDebug();
post back the results that this writes to the page after trying an insert.
the files array:
array(1) {
["Product_Image"]=>
array(5) {
["name"]=>
string(23) "001_GuidanceLeaflet.jpg"
["type"]=>
string(0) ""
["tmp_name"]=>
string(0) ""
["error"]=>
int(6)
["size"]=>
int(0)
shows error 6:
["error"]=>
int(6)
this error means that there is no upload temp dir defined in the php.ini file. you will need top contact the host to have the error corrected.
http://www.php.net/manual/en/features.file-upload.errors.php
UPLOAD_ERR_NO_TMP_DIR
Value: 6; Missing a temporary folder. Introduced in PHP 4.3.10 and PHP 5.0.3.
you will also need to contact the host to determine why you are getting the MySQL Server has Gone away error message.
