Help with search
Thread began 3/07/2014 9:57 am by iainmacdonald331081 | Last modified 3/12/2014 1:40 pm by Jason Byrnes | 2079 views | 18 replies |
iainmacdonald331081
Help with search
This might need to be a paid ticket, but am posting here first as it is hopefully not too far off working.
I have a db structure:
Tables:
Itineraries
ItineraryID (PK)
Itinerary
etc
Activities
ActivityID (PK)
Activity
etc
ItineraryActivities
ItineraryID
ActivityID
I am trying to create a search page where people can fill in some standard search fields, and also drill down by checking boxes to return itineraries that have particular activities associated with them.
I have gotten as far as the search with the text fields all working, and the search page is displaying all the activities along with the check boxes.
The search as it currently works will return results where any of the checked activities are a match.
http://www.safaribookers.com/search101/search101.php
What I can't seem to get is where it will return results where all of the checked activities are a match.
I have attached copies of the search and results page - if anyone could have a quick look and point me in the right direction that would be much appreciated.
Thanks.
add the checkbox to your search form and set it to pass the activity ID as the value.
on the results page, go to bindings, click the plus button and select Form Data, then select the search form to add the search bindings to the results page.
in the data assist saerch behavior, set the Activity Criteria to use the Key Word search type. Set the OR seperator to use a coma followed by a space ", "
for the search value, click the lightning bolt icon and select the activity checkout box
Now, on the search form, edit the name of the activity check box to add "[]" at the end. This will create an array of the activity selections.
on the results page, add the following code to convert the array to a comma separated list:
<?php if(isset($_POST['activities'])) $_POST['activities'] = implode(", ", $_POST['activities']); ?>
the example above assumes the activities checkbox is named activities, if you use a different name, adjust accordingly.
iainmacdonald331081
Thanks Jason.
Haven't been able to get too much further.
Is the checkbox not already on the search page passing ActivityID (the lines 136-141)?
On the results page, when I go to add the search form I only see an option to select a page, rather than a form?
And when I click on the DA Search Behaviour I get prompted to insert a recordset to use DA.
you have hand coding in place that is breaking the ability to use the behavior.
on the update page,
change:
$KeyArr1 = array("Itinerary");
$KeyArr2 = array("ActivityID");
and change:
$WADbSearch1->addComparisonFromList("ActivityID","Activity","AND","=",0);
$WADbSearch1->keywordComparison($KeyArr2,"".((isset($_POST["Activity"]))?$_POST["Activity"]:"")  ."","AND","Includes",",%20","%20","%22","%22",0);
and add this code at line 1:
<?php if(isset($_POST['Activity'])) $_POST['Activity'] = implode(", ", $_POST['Activity']); ?>
iainmacdonald331081
Thanks Jason,
I'd been trying something along those lines as well, but without any luck.
With the above there's something not quite right - with one checkbox ticked it works, but if you select more than one it draws a blank:
http://www.safaribookers.com/search101/search501.php
wa2.zip
you're welcome.
i made 2 changes to fix the problem.
i changed line 1 to:
<?php if(isset($_POST['Activity'])) $_POST['Activity'] = implode(",", $_POST['Activity']); ?>
and line 33 to:
$WADbSearch1->keywordComparison($KeyArr2,"".((isset($_POST["Activity"]))?$_POST["Activity"]:"") ."","AND","=","%20",",","%22","%22",0);
iainmacdonald331081
Thanks Jason - still not working unfortunately. That's returning results with any of the checkboxes ticked.
try this change:
line 1 to:
<?php if(isset($_POST['Activity'])) $_POST['Activity'] = implode(" ", $_POST['Activity']); ?>
and line 33 to:
$WADbSearch1->keywordComparison($KeyArr2,"".((isset($_POST["Activity"]))?$_POST["Activity"]:"") ."","AND","=",",%20","%20","%22","%22",0);
iainmacdonald331081
Sorry Jason - still returning results matching any of the checkboxes ticked.
