Data assist crashes when creating update page
Thread begun 3/07/2014 5:10 am by J7HNW | Last modified 3/10/2014 9:11 am by Jason Byrnes | 4120 views | 13 replies |
J7HNW
I am trying to run of the data assist pages for a simple name and e mail address database table
Data assist crashes every time when it gets to the Update page ( it just hangs on 17 seconds )
Please advise
That error usually happens if you use one of the application presets with a table that does not have the same column names.
If you select to use of of the application presets, you should either select the option to have the table created, or make sure that the table you are using has the same structure.
if you select to use your own table, you should use the new from blank preset and set up the pages to be created manually. you can save the settings as a preset to be used later.
J7HNW
Just tried again using New from Blank ( I only have a 3 column table to capture name and e mail address along with ID )
On each page I selected the 3 columns in my table. Saved it as a Preset
Crashed same error as above
Please advise ?
what is the structure of the table?
is there a primary key column defined?
The error suggests that keyCol is undefined meaning it cant determine the primary key column
J7HNW
I ran it again and now it works so thanks Jason
One more thing - I cannot get BCC copies of UEM to send out
I have tried separating the e mail addresses with a , and a ;
How should these BCC entries be added please
Regards
John
click the BCC button and add them one at a time to the BCC list.
J7HNW
so no commas or seperators ?
no, no separators.
on the BCC screen click the plus to add a BCC address, then click it again to add another one. rinse and repeat....
J7HNW
Thank you
