added email form now only doesn't send email, also doesn't save data
Thread begun 3/06/2014 5:25 am by birdscreen398247 | Last modified 3/06/2014 11:21 am by Jason Byrnes | 1466 views | 3 replies |
birdscreen398247
I have a form with multiple fields that saves to a database and then goes to another form. It worked fine until I tried adding email to send the data to my email address as well as save it to the database. After hitting submit, it just hangs up with no error messages. It doesn't send the mail or save the record to the database. Attached is the file in question.
birdscreen398247
Don't bother. After waiting several hours with no response, I decided to use a different method to accomplish the same thing. I already changed the files, so I can't give you a link to the one that wouldn't work. However, I even tried just setting up a test page using the default Contact form in the WebAssist Form wizard, and it didn't work either. I just downloaded and installed all of the latest versions of DataBridge and ECart a few days ago. It is really upsetting that so often these extensions don't work for even simple procedures. I am on a deadline here and I have spent several days trying to get the email to work, so I don't have anymore time to play with it. Maybe another time.
If you run into a problem again, let us know and we will look into the cause.
