Cannot find existing sql error near @
Thread begun 3/05/2014 11:40 am by jdjandcompany430226 | Last modified 3/20/2014 12:10 pm by Jason Byrnes | 4890 views | 9 replies |
jdjandcompany430226
ok I have issues with the UE contact page seems to never work and the forgot password gives an sql error when column type is varchar and when set to text wont read at all.
jdjandcompany430226
SQL errors
I have many errors with the emailer.
the error message on the forgot password page is caused by this line:
"columnType" => "char",
it should be:
"columnType" => "text",
as for the email failing, Who is your host?
Depending on your host, you may need to set certain options in Universal Email.
Some hosts will work if you leave the SMTP Server setting on the Email Server Tab blank, others will require that you enter the SMTP server address.
Some will work using the standard Mail protocol, other will require that you use the Pear Mail for SMTP, some using Pear mail will require authentication.
Some hosts may require that the from address being used be a valid email address for your domain. Some may require that the option to include the from Email address be passed as an extra parameter.
To be successful with Universal Email, you will need to know the requirements of your host for sending an email using a PHP script.
Also, double check your Spam folder, it is possible that the email is being trapped as spam.
jdjandcompany430226
in addition here is the return I am getting (forgotpassword.php?notFound=1&EmailFail=true)
Yes, that is because the email settings for the server are not correct which is why i asked these questions in my previous reply that you did not address:
jdjandcompany430226
Message attached
see PM
jdjandcompany430226
Message Attached in PM
on this page:
http://www.awardspace.com/contacts/faq-help
in the email management section, the post:
Example contact form (form-to-mail).
gives an example of sending an email using php mail.
it looks like the smtp server and port should be left blank.
note in the example:
$myemail = "youremail@yourdomain.com"; Caution: replace youremail@yourdomain.com with a vaild one you created in Email Manager
this is the to address. So it sounds like they will only allow you to send emails that are going to an email you register for your domain. It sounds like they do not allow for outgoing email traffic to other domains.
you may want to look into another host that is not so restrictive with sending emails. I use 1 and 1 and have very good experience with them.
