Hiding product variable drop-downs if product variables doesn't exist?
Thread begun 3/05/2014 8:44 am by Nathon Jones Web Design | Last modified 3/05/2014 8:52 am by Jason Byrnes | 876 views | 1 replies |
Hiding product variable drop-downs if product variable doesn't exist?
If you go to this page:
http://www.ledwarehouseuk.com/LED-Tube-Lights.php
...and select the first product's "View / Buy" button you are taken to the product detail page.
This product doesn't have a colour or dimmable option so I'd like those two drop down menu's to be hidden whilst, obviously, not affecting my Add to Cart behaviour.
How do I achieve this?
Thank you.
NJ
do you use a recordset to populate those lists?
if so, use the Show if recordset is not empty behavior. that way if the recordset does not return any options, it will hide the list.
you will need to add a hidden form element of the same name and use the show if recordset is empty so that the form element will still exist if the recordset does not return any options.
