PowerGallery 2.1
Thread begun 3/02/2014 9:39 am by rob294118 | Last modified 10/24/2014 9:18 am by Jason Byrnes | 6643 views | 17 replies |
rob294118
PowerGallery 2.1
I am getting this error on my galleries all of a sudden.
Warning: opendir(PowerGallery/galleries/ribbon_fullsize_lightbox/css/themes) [function.opendir]: failed to open dir: No such file or directory in /homepages/20/d184490718/htdocs/CharlieKristine/PowerGallery/admin_gallery/common/functions.php on line 491
The website is: http://www.charliekristine.com/photos_glamour_lingerie.php
Thanks.
rob294118
Info
ok
see PM
rob294118
Thanks a lot Jason.
you're welcome.
info266692
Power Gallery Themes error
I think i'm expiriencing the same problem of rob294118 (3/02/2014 12:39 pm | #1 rob294118) my gallery.php page display the gallery without using the assigned Themes from Power Gallery. The message on the page is "Warning: opendir(/home/promotio/public_html/WA_Globals/galleries/ribbon_fullsize_lightbox/css/themes): failed to open dir: No such file or directory in /home/promotio/public_html/gallery/admin_gallery/common/functions.php on line 490". By the look the codes are OK in that line (490) but I'm not 100% sure. Can you help?
Alfredo from OZ
info266692
Hi Jason,
I've managed to resolve the issues I experienced with the Power Gallery themes, however that was not the only problem I had with the PG installation, luckily I've found the answers in this forum to every problem I’ve encountered.
I’m in the process of installing one other PG into a different web site but with the same hosting service; I will let you know if I’m stumbling in similar problems.
Alfredo
Hi Jason,
I was expecting more problems with the new installation of PG into a different web site and behold I’ve just got into problems again. This time I can't even login into the Administration area of PG because nothing appears into my browser screen. I will send you details in regard FTP and web site address in the Private Message area.
Alfredo
i updated the admin_gallery/global.php file to fix the problem.
