unverified user is able to access secure pages?
Thread begun 3/01/2014 2:14 pm by Mags | Last modified 3/04/2014 12:20 pm by Jason Byrnes | 2744 views | 7 replies |
Mags
I've set up a slightly modified double opt-in user registration system. Instead of the person verifying themselves via email, I've set it up so that an email goes to the administrator who then decides whether or not to allow access. This changes the "userVerified" column from a 0 to 1 and the user then gets access. All works fine, apart from one thing which I discovered by accident - immediately after registering (at which point the user gets a screen telling them they will be emailed when their account is approved), if they then try to access any of the secure pages directly, they can view them. This is while their userVerified state is still set to 0. If they logout and then try to login again however, they can't get access (until of course their status is set to 1 by the administrator). Any idea why this would be?
sysop349733
It sounds to me as if you have not updated the access rule on the pages in question. Have you used Security Assist Access Page Manager to change the allow rule from allowed if logged in to allowed if verified?
There is a new tutorial that may help you: http://www.webassist.com/tutorials/User-level-authentication-with-SecurityAssist
Mags
Yes, I used the Access Pages Manager to secure the pages and it does work in all other circumstances - if the userVerified value is 0, the user can't access the pages and if it's 1, they can. When the user first registers, their account is set to 0 and when approved it changes to 1. In Access Pages Manager, I have a Verified User rule applied to the secure pages as follows:
Restrict if: <?php echo $_SESSION['SecurityAssist_UserID']; ?> =
Allow if: <?php echo $_SESSION['userVerified']; ?> = 1
Restrict if: <?php echo $_SESSION['userVerified']; ?> = 0
What seems to be happening is that, when the user registers, it's logging them in at the same time and before their account has been approved, they can access the secure pages. However, if they logout and then try to login again, they can't, until someone approves their account.
It seems to be a similar issue which was reported in the post here: http://www.webassist.com/forums/posts.php?id=33668 however most of the replies are in PMs so I can't see how or if it was resolved.
sysop349733
You probably need help from someone with Webassist on this (which I am not -- just another user), but I wonder about the restrict if userID = [blank] , if that's not part of the problem, I'd also check to make sure that the session variable userVerified is being properly set on the login page. Sorry if that's not much help.
Mags
I wondered that too, but that bit of the system was taken directly from the tutorial on setting up a double opt-in registration. I tried removing it to see what would happen but it removed the protection completely. Thanks for your suggestions, hopefully someone at WebAssist can help!
remove the third condition of the rule:
When the user registers the userVerified session is not set, so it evaluates the conditions as:
SecurityAssist_UserID Has a value, so look at next rule
userVerified does not have a value, so is not = to 1, look at next rule
userVerified does not have a value, so is not = to 0. Since this is the last rule it will allow access since it cant restrict access.
Mags
Many thanks Jason, that fixed it!
you're welcome.
