After setting up CMS, I get an error message in my browser after submitting my db information.
Thread began 3/01/2014 1:37 pm by sschultz284418 | Last modified 3/03/2014 11:25 am by Jason Byrnes | 1142 views | 5 replies |
sschultz284418
After setting up CMS, I get the following error message in my browser after entering my db information:
Notice: Undefined variable: tagName in C:\Xampp For Windows\htdocs\grossitsystems\webassist\framework\framework.php on line 177
Fatal error: Maximum execution time of 30 seconds exceeded in C:\Xampp For Windows\htdocs\grossitsystems\install_cms\database.php on line 129
I'm testing my site locally using XAMPP
MYSQL
•Server: localhost via TCP/IP
•Server version: 5.5.16
•Protocol version: 10
•User: root@localhost
WEBSERVER
•Apache/2.2.21 (Win32) mod_ssl/2.2.21 OpenSSL/1.0.0e PHP/5.3.8 mod_perl/2.0.4 Perl/v5.10.1
•MySQL client version: mysqlnd 5.0.8-dev - 20102224 - $Revision: 310735 $
•PHP extension: mysql[/i]
here is an updated copy of the webassist\framework\framework.php file that should correct the error
framework.php.zip
sschultz284418
Script Times Out
Thanks, Jason. The new file helped, but now I get the following error:
try adding the following code at line 1 of the install_cms\database.php file.
<?php   set_time_limit(0); ?>
sschultz284418
Success!
Jason - That worked. Thanks for your help!
you're welcome.
