Design Extender Does not Install on Dreamweaver CC
Thread began 2/24/2014 1:31 pm by brad3917861 | Last modified 2/25/2014 7:46 am by Jason Byrnes | 1653 views | 3 replies |
brad3917861
I am trying to install Design Extender but I keep getting the message; Design Extender Requires Dreamweaver 9 or Greater. I purchased the upgrade after the site said I needed the new version to make my extensions work. Can you please help with why I cannot get this installed?
After you download the Design Extender ZXP file from our site, don't double click it to start the install, instead, open the extension manager, in the extension manager click the install button and browse to the downloaded ZXP file.
brad3917861
Found the real problem
I found the real problem, your a Red Sox fan. Our worlds are not compatible. My family is from New York and I am in Colorado just kidding. The real problem was I do have CS6 and by default CC does not install extensions for CC. Your recommendation also solved the problem so if anyone cares step one update your extension manager and step two do not double click the extension install it through the manager. Thanks for your help.
Yes, the CC Extension manager does not install automatically. In order to manage extensions for DW CC, you need to install the CC Extension Manager.
The Real issue, though, is caused by double clicking the extension to install it. If you have multiple versions of DW installed, it will install to the default which may not be the one you expect.
