Failure on Submit, again.
Thread began 8/20/2009 8:29 am by mick106153 | Last modified 8/20/2009 10:13 am by Jason Byrnes | 1051 views | 1 replies |
mick106153
After updating the WA_eCart_USPS_PHP.php file several days ago everything worked as expected.
Last night I added several products and options and this morning when I tested a purchase I got the following error on "Submit"…
The numbers have been changed to protect the innocent.
Mick
Your transaction could not be completed. Either your credit card information or billing address has problems and cannot be processed
Please return to checkout and try again.
x_login=4a3MKx24&x_tran_key=8e3P68cM7S6na6RR&x_version=3.1&x_invoice_num=05f1ac15fb6786963f583c40a344e41d&x_test_request=TRUE&x_method=CC&x_type=AUTH_CAPTURE&x_relay_response=FALSE&x_delim_data=TRUE&x_delim_char=::&x_customer_ip=166.155.200.174&x_amount=97.79&x_description=2 IM INTO HORSES RU2 hoodie (3), 1 IM INTO HORSES RU2 hoodie (133)&x_line_item=3<|>IM INTO HORSES RU2 hoodie<|>
Full Zip 50/50 poly cotton blend Black Hoodie with over the heart graphic embroidery shorthand for Im Into Horses Are You Too?"
--Size: Small, Color: Black, Design Color: Pink & White<|>2<|>28.5<|>YES&x_line_item=133<|>IM INTO HORSES RU2 hoodie<|>
Full Zip 50/50 poly cotton blend Navy Hoodie with over the heart graphic embroidery shorthand for Im Into Horses Are You Too?"
--Size: Small, Color: Navy, Design Color: Copper & White<|>1<|>28.5<|>YES&x_card_num=xxxxxxxxxxxxxxxx&x_exp_date=000000&x_card_code=999&x_email_customer=TRUE&x_tax=6.84&x_tax_exempt=FALSE&x_freight=5.45&x_first_name=Mick&x_last_name=Natco&x_address=XXXXXXXXXX Road&x_city=Burton&x_state=OH&x_zip=44021&x_phone=xxx-XXX-xxxx&x_fax=&x_email=mick@lpgp.com&x_country=US&x_ship_to_first_name=Mick&x_ship_to_last_name=Natco&x_ship_to_address=XXXXXXXXXXXX Road&x_ship_to_city=Burton&x_ship_to_state=OH&x_ship_to_zip=44021&x_ship_to_country=US&x_ship_to_phone=xxx-XXX-xxxx&x_ship_to_fax=&x_recurring_billing=NO3::1::270::(TESTMODE) Line item 1 is invalid.::000000::P::0::05f1ac15fb6786963f58::2 IM INTO HORSES RU2 hoodie (3), 1 IM INTO HORSES RU2 hoodie (133)::97.79::CC::auth_capture::::Mick::Natco::::xxxxxxxxxxxxxx Road::Burton::OH::44021::US::xxx-XXX-xxxx::::mick@lpgp.com::Mick::Natco::::xxxxxxxxxxxxxxxxxRoad::Burton::OH::44021::US::6.8400::::5.4500::FALSE::::C015DA14CB24F03FB1920B51E2A8FA93::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::xxx-XXX-xxxx::
The error you are getting is "Line item 1 is invalid".
This error occurs if you are passing illegal characters through the name or description of the itmes in your cart.
Double check the names and desriptions do not contain any HTML characters.
